[pgrouting-users] Problems recalculating the network topology
Stephen Woodbridge woodbri at swoodbridge.com
Thu Jul 8 11:49:25 EDT 2010
Peter Hopfgartner wrote:
> Dear pgRouting tribe!
> I would like to run assign_vertex_id() for a simple table, like the
> following:
> CREATE TABLE dhl_ret_l
>   gid integer NOT NULL,
>   the_geom geometry,
>   source integer,
>   target integer,
>   length double precision,
>   "cluster" integer,
>   CONSTRAINT dhl_ret_l_pkey PRIMARY KEY (gid),
>   CONSTRAINT enforce_dims_the_geom CHECK (st_ndims(the_geom) = 2),
>   CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
> 'LINESTRING'::text OR the_geom IS NULL),
>   CONSTRAINT enforce_srid_the_geom CHECK (st_srid(the_geom) = 3003)
> This is fine for the first time. Now I would like to recalculate the
> network topology, so I do:
> SELECT DropGeometryColumn('public', 'vertices_tmp', 'the_geom');
> DROP TABLE vertices_tmp;
Try doing:
DROP TABLE vertices_tmp CASCADE;
-Steve
> and try to restart the calculation:
> SELECT assign_vertex_id('dhl_ret_l', 0.00, 'the_geom', 'gid');
> and get the following error:
> NOTICE:  CREATE TABLE will create implicit sequence
> "vertices_tmp_id_seq" for serial column "vertices_tmp.id"
> CONTEXT:  SQL statement "CREATE TABLE vertices_tmp (id serial)"
> PL/pgSQL function "assign_vertex_id" line 14 at execute statement
> CONTEXT:  PL/pgSQL function "assign_vertex_id" line 29 at assignment
> ERROR:  relation with OID 5843275 does not exist
> CONTEXT:  SQL statement "SELECT
> Distance(the_geom,GeometryFromText( AsText( $1 ),  $2 )) AS d, id,
> the_geom FROM vertices_tmp WHERE the_geom &&
> Expand(GeometryFromText(AsText( $1 ),  $2 ),  $3  ) AND
> Distance(the_geom, GeometryFromText(AsText( $1 ),  $2 )) <  $3  ORDER BY
> d LIMIT 1"
> PL/pgSQL function "point_to_id" line 13 at SQL statement
> What am I doing wrongly?
> Regards,
> Peter
More information about the Pgrouting-users mailing list
