[pgrouting-users] ordering of route edges?
Madison Shaw madisonshaw at googlemail.com
Mon Nov 29 13:46:10 EST 2010
Hi Daniel,
Thanks for the quick reply, my SQL statement and its results are below
(with pre selected start and finish points for ease of illustrating my
issue)
As you can see, the edge (gid) that we start from '1' is given the id of 29.
SELECT gid, the_geom FROM dijkstra_sp_delta('roads',1,400,0.1)
Results
id; gid; the_geom
1;15;"0102 ... B40"
2;17;"0102 ... B40"
3;1139;"0102 ... B40"
4;746;"0102 ... B40"
5;879;"0102 ... B40"
6;12;"0102 ... B40"
7;1133;"0102 ... B40"
8;9283;"0102 ... B40"
9;7;"0102 ... B40"
10;1137;"0102 ... B40"
11;875;"0102 ... B40"
12;880;"0102 ... B40"
13;634;"0102 ... B40"
14;637;"0102 ... B40"
15;4;"0102 ... B40"
16;18;"0102 ... B40"
17;19;"0102 ... B40"
18;14;"0102 ... B40"
19;1143;"0102 ... B40"
20;1135;"0102 ... B40"
21;1259;"0102 ... B40"
22;109;"0102 ... B40"
23;1129;"0102 ... B40"
24;1136;"0102 ... B40"
25;1130;"0102 ... B40"
26;1131;"0102 ... B40"
27;1146;"0102 ... B40"
28;876;"0102 ... B40"
29;1;"0102 ... B40"
30;9;"0102 ... B40"
31;11;"0102 ... B40"
32;1132;"0102 ... B40"
33;8759;"0102 ... B40"
34;1138;"0102 ... B40"
35;1260;"0102 ... B40"
36;8;"0102 ... B40"
37;10;"0102 ... B40"
38;1128;"0102 ... B40"
39;1142;"0102 ... B40"
40;1134;"0102 ... B40"
41;1147;"0102 ... B40"
42;16;"0102 ... B40"
43;13;"0102 ... B40"
44;1140;"0102 ... B40"
45;1258;"0102 ... B40"
Cheers
Madison
On 29 November 2010 18:30, Daniel Kastl <daniel at georepublic.de> wrote:
> Hi Madison,
> Could you send me your routing query to see how it looks like?
> Daniel
> 2010/11/30 Madison Shaw <madisonshaw at googlemail.com>
>> Hi There,
>> I was wondering if someone could help me.  I have pgrouting working
>> and producing routes using both Dijkstra and AStar, but the edges that
>> are returned by the SQL are in the wrong order... not the order of the
>> edges as you expect to move through the route from start to finish...
>> eg: (using a short example)
>> If I have a route of ten edges, from start edge 1 to finish edge 10 -
>> I would expect the results to be: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 (using
>> the id column that is returned from the sql)
>> However, the results are more like 3, 6, 2, 8, 1, 9, 4, 7, 10, 5.
>> Is this supposed to happen? Is there a way to return the results in
>> the order you traverse through the route?
>> Cheers
>> Madison
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
More information about the Pgrouting-users mailing list
