[pgrouting-users] Problem with long edges
Julien-Samuel Lacroix
jlacroix at mapgears.com
Wed Oct 27 14:59:04 EDT 2010
I use shortest_path_astar() to do the routing in my application. If I
understand correctly, this mean that I can do routing from one line
segment to another line segment.
I have a problem with line segment that are big loops (see attached
image). In my example, the green and red points are my start and end
point. Ideally I would like to pass through 95-29, but both points are
on edge 95-28. If I understand correctly, I can't use
shortest_path_astar(). Right?
Any idea to make this work?
Best regards,
Julien
Mapgears
http://www.mapgears.com/
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20101027/1abd8f9c/bug_routing_loop.png
More information about the Pgrouting-users
