[pgrouting-users] Thoughts on how elevation in routing
Stephen Woodbridge woodbri at swoodbridge.com
Mon Sep 13 10:28:54 EDT 2010
Hi all,
I have preprocessed some shapefile data and added elevation information
in the Z value of the coordinates. I'm wondering how to best utilize
that in routes and would like any thoughts or ideas you might be willing
to share.
The obvious answer is to wrap the elevation data into the cost values as
this is simple and straight forward and does not require code changes.
This brings me to what have other people done or thought about doing in
this regard?
Here are some random thoughts I have had on this in no particular order:
o for bicycles, we probably only care about UP grade and length. This
would imply that segments need to be in a directed graph with different
costs going from A-B vs. B-A based on the upgrade
o for trucks, maybe an un-directed graph is ok, because they need to use
low gear both up and down depending on the grade and length
o for motorcycles, hilly terrain tends to mean more twisty roads which
are more fun to ride so lower costs for roads with lots of elevation
changes.
grade = (rise / run) * 100
where run should be the 2D length of the segment.
Is there a "standard" way of factoring grade into the route calculations?
Thanks,
   -Steve
More information about the Pgrouting-users mailing list
