[pgrouting-users] filtering the data used for shortest path
calculations
Dan Putler
putler at yahoo.com
Sat Apr 9 18:15:25 EDT 2011
You can effectively doing this by making the travel costs of Street X's segment very high. Doing this causes the algorithm to exclude the those segments from the solution since using them is costs.
--- On Sat, 4/9/11, James Mueller <jmuel11 at gmail.com> wrote:
Subject: [pgrouting-users] filtering the data used for shortest path calculations
To: pgrouting-users at lists.osgeo.org
Received: Saturday, April 9, 2011, 2:46 PM
Is it possible to filter out subpaths on the shortest path calculations? For example, if I wanted to use djikstra's algorithm to calculate the shortest path between point A and point B without using Street X?
-----Inline Attachment Follows-----
Pgrouting-users mailing list
Pgrouting-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110409/ed99856f/attachment.html
More information about the Pgrouting-users
