[pgrouting-users] filtering the data used for shortest
	path	calculations
    Stephen Woodbridge
    woodbri at swoodbridge.com
    Mon Apr 11 21:51:12 EDT 2011
A simplier approach to this is to modify the wrapper plpgsql function to
filter out the street by name or unique id. Basically the wrapper
functions take a start and end point and construct an expanded bbox that
is used to load the the segments into the graph that get solved.
Something like:
select .... from table where the_geom && st_expand(setsrid(makeline(p1,
p2), 4326);
change this to be:
p2), 4326) AND gid != exclude_gid;
or:
p2), 4326) AND name != exclude_name;
and you can clone the wrapper function and add a new parameter for exclude_*
-Steve
On 4/9/2011 6:15 PM, Dan Putler wrote:
> You can effectively doing this by making the travel costs of Street X's
> segment very high. Doing this causes the algorithm to exclude the those
> segments from the solution since using them is costs.
> --- On *Sat, 4/9/11, James Mueller /<jmuel11 at gmail.com>/* wrote:
>     From: James Mueller <jmuel11 at gmail.com>
>     Subject: [pgrouting-users] filtering the data used for shortest path
>     calculations
>     To: pgrouting-users at lists.osgeo.org
>     Received: Saturday, April 9, 2011, 2:46 PM
>     Is it possible to filter out subpaths on the shortest path
>     calculations? For example, if I wanted to use djikstra's algorithm
>     to calculate the shortest path between point A and point B without
>     using Street X?
>     -----Inline Attachment Follows-----
>     _______________________________________________
>     Pgrouting-users mailing list
>     Pgrouting-users at lists.osgeo.org
>     </mc/compose?to=Pgrouting-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
