[pgrouting-users] assign_vertices_3d source code & docs
Miroslav Novta miroslav.novta at gmail.com
Tue Apr 12 18:01:28 EDT 2011
Hi all,
Thanks you for your advices, the issue is fixed.
It was just a type of apostrophe, copy/paste from html howto guide gives
wrong type of apostrophe. I have missed it because I've used phpPgAdmin
without syntax highlight. After I start using pgAdmin III everything
was highlighted
and better.
Regards,
Miroslav
2011/3/29 Stephen Woodbridge <woodbri at swoodbridge.com>
> The easier way to do this is to liberally add
> RAISE NOTICE 'some text var1=% var2=%', var1, var2;
> to the functions and then these values will get printed as the code is
> executed.
> If the function compute some SQL that then gets executed then print out the
> SQL and you can then execute the same SQL in psql.
> sql := 'select ....';
> RAISE NOTICE 'SQL: %', sql
> EXECUTE sql;
> -Steve
> On 3/29/2011 10:22 AM, Charles Galpin wrote:
>> I don't know how to get a line number from the function to see where
>> it's failing so I'd just try each step by hand and see what fails.
>> hth
>> charles
>> On Mar 28, 2011, at 6:04 PM, Miroslav Novta wrote:
>>  Hi Steve,
>>> It has changed table name to the_network and after that to ways. Error
>>> is same all the time. Is there something wrong in function? Or i am
>>> missing something?
>>> *SQL error:*
>>> ERROR:  column"’the_network’"  does not exist
>>> LINE 1: SELECT assign_vertex_id3d(’the_network’, 1, ’the_geom’, ’gid...
>>> *In statement:*
>>> SELECT assign_vertex_id3d(’the_network’, 1, ’the_geom’, ’gid’,
>>> 'F_LEVEL', 'T_LEVEL');
>>> Function assign_vertex_id3d is bellow
>>> assign_vertex_id3d      "geom_table" character varying, "tolerance"
>>> double
>>> precision, "geo_cname" character varying, "gid_cname" character
>>> varying, "source_zlevel_cname" character varying,
>>> "target_zlevel_cname" character varying         character varying
>>> plpgsql
>>> Definition
>>> 1
>>> 2
>>> 3
>>> 4
>>> 5
>>> 6
>>> 7
>>> 8
>>> 9
>>> 10
>>> 11
>>> 12
>>> 13
>>> 14
>>> 15
>>> 16
>>> 17
>>> 18
>>> 19
>>> 20
>>> 21
>>> 22
>>> 23
>>> 24
>>> 25
>>> 26
>>> 27
>>> 28
>>> 29
>>> 30
>>> 31
>>> 32
>>> 33
>>> 34
>>> 35
>>> 36
>>> 37
>>> 38
>>> 39
>>> 40
>>> 41
>>> 42
>>> 43
>>> 44
>>> 45
>>> DECLARE
>>>    _r record;
>>>    source_idint;
>>>    target_idint;
>>>    sridinteger;
>>> BEGIN
>>>    BEGIN
>>>    DROP  TABLE  vertices_tmp;
>>>    EXCEPTION
>>>    WHEN  UNDEFINED_TABLETHEN
>>>    END;
>>>    EXECUTE  'CREATE TABLE vertices_tmp (id serial)';
>>> --    FOR _r IN EXECUTE'SELECT srid FROM geometry_columns WHERE
>>> f_table_name='''|| quote_ident(geom_table)||''';'  LOOP
>>> --      srid := _r.srid;
>>> --    END LOOP;
>>>    srid :=
>>> Find_SRID('public',quote_ident(geom_table),quote_ident(geo_cname));
>>>    EXECUTE  'SELECT
>>> addGeometryColumn(''vertices_tmp'',''the_geom'','||srid||',''POINT'', 3)';
>>>    CREATE  INDEX  vertices_tmp_idxON  vertices_tmpUSING  GIST (the_geom);
>>>    FOR  _rIN  EXECUTE  'SELECT'  || quote_ident(gid_cname) ||'  AS id,'
>>>            ||'  ST_MakePoint(ST_X(StartPoint('|| quote_ident(geo_cname)
>>> ||')), ST_Y(StartPoint('|| quote_ident(geo_cname) ||')),'||
>>> quote_ident(source_zlevel_cname) ||') AS source,'
>>>            ||'  ST_MakePoint(ST_X(EndPoint('|| quote_ident(geo_cname)
>>> ||')), ST_Y(EndPoint('|| quote_ident(geo_cname) ||')),'||
>>> quote_ident(target_zlevel_cname) ||') AS target'
>>>            ||'  FROM'  || quote_ident(geom_table)
>>>    LOOP
>>>        source_id := point_to_id3d(setsrid(_r.source, srid), tolerance);
>>>        target_id := point_to_id3d(setsrid(_r.target, srid), tolerance);
>>>        EXECUTE  'update'  || quote_ident(geom_table) ||
>>>                '  SET source ='  || source_id ||
>>>                ', target ='  || target_id ||
>>>                '  WHERE'  || quote_ident(gid_cname) ||'  ='  || _r.id  <
>>> http://r.id/>;
>>>    END  LOOP;
>>>    RETURN  'OK';
>>> END;
>>> - Miroslav
>>> 2011/3/25 Stephen Woodbridge <woodbri at swoodbridge.com
>>> <mailto:woodbri at swoodbridge.com>>
>>>    network is a postgresql type so it must be quoted. So you can try
>>>    doing:
>>>    SELECT assign_vertex_id3d(’"network"’, 1, ’the_geom’, ’gid’,
>>>    This might work, but in general you might have other issues with
>>>    other stored procedures also.
>>>    You could also try changing your table name like:
>>>    alter table "network" rename to "the_network";
>>>    then reference it by the_network like:
>>>    -Steve
>>>    On 3/24/2011 6:32 PM, Miroslav Novta wrote:
>>>        Hello Dear,
>>>        I have faced a problem with assign_vertex_id3d. It is a bit
>>>        strange
>>>        error message i have get. I have explored all code i suspect
>>>        and have no
>>>        clue. Error report is network is not a column, it is a table
>>>        and it
>>>        should be a table, i have no idea why it expect it to be a column.
>>>        Here is error i get:
>>>        ERROR: column "’network’" does not exist
>>>        LINE 1: SELECT assign_vertex_id3d(’network’, 1, ’the_geom’,
>>>        ’gid’, '...
>>>        In statement:
>>>        SELECT assign_vertex_id3d(’network’, 1, ’the_geom’, ’gid’,
>>>        'F_LEVEL',
>>>        'T_LEVEL');
>>>        To explain more, network is my ways table defined with iGO
>>>        standard. I
>>>        have added source and target columns according to guide
>>>        -- Add "source" and "target" column
>>>        ALTER TABLE "network" ADD COLUMN "source" integer;
>>>        ALTER TABLE "network" ADD COLUMN "target" integer;
>>>        Do you have any idea what is wrong? What have i missed?
>>>        Regards,
>>>        Miroslav
>>>        2011/3/23 Stephen Woodbridge <woodbri at swoodbridge.com
>>>        <mailto:woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com
>>>        > On 3/23/2011 10:23 AM, Miroslav Novta wrote:
>>>        >> Steve,
>>>        >> Thank you, I will follow your Instructions. I don't expect
>>>        a lot of
>>>        >> problems with turn restrictions because maneuvers table is
>>>        still empty
>>>        >> and will be filled after routing become functional.
>>>        >> I still have some baby problems to make pgRouting functional.
>>>        >> For example what is correct range of tolerance if i use
>>>        meters not
>>>        >> degrees in assign vertex?
>>>        > This depends on your data for example in degrees if you data
>>>        has a
>>>        resolution of 0.000001 then this is a good value to use.
>>>        > For meters, you might use 0.5 or 0.9, the best way to
>>>        evaluate this
>>>        is to look the the coordinates at the ends of to segments that
>>>        should be
>>>        connected. So:
>>>        > abs(Xa - Xb) < tolerance
>>>        > to match the two ends to the same node. If you set tolerance
>>>        too big
>>>        then it will merge close by nodes that should not be
>>>        connected. If you
>>>        set the tolerance too small it will not match nodes that should be
>>>        connected. We use tolerance to deal with floating point
>>>        numbers not
>>>        being exact like integers and can have rounding errors in the
>>>        numbers.
>>>        > -Steve
>>>        >> Miroslav
>>>        <mailto:woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>>
>>>        <mailto:woodbri at swoodbridge.com>>>>
>>>        >> Charles,
>>>        >> Thank you for posting that. I am glad I read the whole thread
>>>        >> because I was just about to did up my old code and dust it
>>>        off to
>>>        >> post. There is no need for that as your implementation
>>>        accurately
>>>        >> reflects mine.
>>>        >> Miroslav,
>>>        >> Regarding turn restrictions, you should search the archives
>>>        for this
>>>        >> as I have been fairly vocal about the limitations. To
>>>        summarize:
>>>        >> 1. turn restrictions only work with shooting star
>>>        >> 2. If you have multiple turn restrictions, I think you have
>>>        to enter
>>>        >> the related links multiple times, ie: once for each restriction
>>>        >> 3. IMHO, we need to rework the turn restrictions to make
>>>        adding them
>>>        >> more intuitive and easier
>>>        >> 4. before you try to implement a large number of them, I would
>>>        >> verify that you can in fact add multiple turn restrictions in a
>>>        >> trivial graph that is easy to verify if it works as expected,
>>>        >> because it is my sense that this area has not been used to
>>>        any great
>>>        >> extent.
>>>        >> -Steve
>>>        >> On 3/23/2011 7:43 AM, Charles Galpin wrote:
>>>        >> Hi Miroslav
>>>        >> This is an implementation I have been using which I made
>>>        after a
>>>        >> discussion with Stephen on this subject. It is essentially an
>>>        >> implementation of his ideas and works fine for me, but ymmv.
>>>        >> Otherwise search the email archives as I believe he posted
>>>        his here
>>>        >> at some point as well.
>>>        >> hth charles
>>>        >> On Mar 23, 2011, at 6:44 AM, Miroslav Novta wrote:
>>>        >> Hello list,
>>>        >> I want to use the assign_vertices_3d() function developed by
>>>        >> Stephen Woodbridge. I want to use it for iGO shp map
>>>        format with
>>>        >> "turn restrictions" too.
>>>        >> Is there source code and documentation available on any
>>>        public
>>>        >> repository I may access?
>>>        >> -- Function: assign_vertex_id3d(character varying, double
>>>        precision,
>>>        >> character varying, character varying, character varying,
>>>        character
>>>        >> varying)
>>>        >> -- DROP FUNCTION assign_vertex_id3d(character varying, double
>>>        >> precision, character varying, character varying, character
>>>        varying,
>>>        >> character varying);
>>>        >> CREATE OR REPLACE FUNCTION assign_vertex_id3d(geom_table
>>>        character
>>>        >> varying, tolerance double precision, geo_cname character
>>>        varying,
>>>        >> gid_cname character varying, source_zlevel_cname character
>>>        varying,
>>>        >> target_zlevel_cname character varying) RETURNS character
>>>        varying AS
>>>        >> $BODY$ DECLARE _r record; source_id int; target_id int; srid
>>>        >> integer; BEGIN
>>>        >> BEGIN DROP TABLE vertices_tmp; EXCEPTION WHEN UNDEFINED_TABLE
>>>        THEN
>>>        >> END;
>>>        >> -- FOR _r IN EXECUTE 'SELECT srid FROM geometry_columns WHERE
>>>        >> f_table_name='''|| quote_ident(geom_table)||''';' LOOP --
>>>        srid
>>>        >> := _r.srid; -- END LOOP;
>>>        >> srid :=
>>>        >> EXECUTE 'SELECT addGeometryColumn(''vertices_tmp'',
>>>        ''the_geom'',
>>>        >> '||srid||', ''POINT'', 3)'; CREATE INDEX vertices_tmp_idx ON
>>>        >> vertices_tmp USING GIST (the_geom);
>>>        >> FOR _r IN EXECUTE 'SELECT ' || quote_ident(gid_cname) || ' AS
>>>        >> id,' ||
>>>        >> ST_Y(StartPoint('|| quote_ident(geo_cname) ||')), '||
>>>        >> quote_ident(source_zlevel_cname) ||') AS source,' || '
>>>        >> ST_MakePoint(ST_X(EndPoint('|| quote_ident(geo_cname) ||')),
>>>        >> ST_Y(EndPoint('|| quote_ident(geo_cname) ||')), '||
>>>        >> quote_ident(target_zlevel_cname) ||') AS target' || ' FROM ' ||
>>>        >> quote_ident(geom_table) LOOP
>>>        tolerance);
>>>        tolerance);
>>>        >> EXECUTE 'update ' || quote_ident(geom_table) || ' SET source
>>>        >> source_id || ', target = ' || target_id || ' WHERE ' ||
>>>        >> quote_ident(gid_cname) || ' = ' || _r.id <http://r.id/>
>>>        <http://r.id <http://r.id/>>
>>>        <http://r.id <http://r.id/>>; END LOOP;
>>>        >> RETURN 'OK';
>>>        >> END; $BODY$ LANGUAGE 'plpgsql' VOLATILE STRICT COST 100; ALTER
>>>        precision,
>>>        character
>>>        >> varying) OWNER TO postgres;
>>>        >> -- Function: point_to_id3d(geometry, double precision)
>>>        >> -- DROP FUNCTION point_to_id3d(geometry, double precision);
>>>        >> CREATE OR REPLACE FUNCTION point_to_id3d(p geometry, tolerance
>>>        >> double
>>>        >> precision) RETURNS bigint AS $BODY$
>>>        >> DECLARE _r record; _id bigint; _srid integer;
>>>        >> BEGIN
>>>        >> _srid := Find_SRID('public','vertices_tmp','the_geom');
>>>        >> SELECT ST_Length3D(ST_MakeLine(the_geom,p)) AS d, id
>>>        >> INTO _r FROM vertices_tmp WHERE
>>>        >> the_geom&& Expand(p, tolerance) AND
>>>        >> ST_Length3D(ST_MakeLine(the_geom,p))< tolerance
>>>        >> ORDER BY d LIMIT 1;
>>>        >> IF FOUND THEN
>>>        >> _id:= _r.id <http://r.id/> <http://r.id <http://r.id/>>
>>>        >> ELSE
>>>        >> INSERT INTO vertices_tmp(the_geom) VALUES (SetSRID(p,_srid));
>>>        >> _id:=lastval();
>>>        >> END IF;
>>>        >> RETURN _id;
>>>        >> FUNCTION point_to_id3d(geometry, double precision) OWNER TO
>>>        >> postgres;
>>>        >> _______________________________________________ Pgrouting-users
>>>        >> mailing list Pgrouting-users at lists.osgeo.org
>>>        <mailto:Pgrouting-users at lists.osgeo.org>
>>>        <mailto:Pgrouting-users at lists.osgeo.org>>
>>>        <mailto:Pgrouting-users at lists.osgeo.org>>>
>>>        >> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>>>        >> Pgrouting-users mailing list
>>>        >> Miroslav Novta
>>>        Miroslav Novta
>>> Miroslav Novta
>>> Pgrouting-users at lists.osgeo.org <mailto:Pgrouting-users at lists.osgeo.org>
Miroslav Novta
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110413/9041dc8e/attachment-0001.html
More information about the Pgrouting-users mailing list
