[pgrouting-users] What is the architecture of pgRouting and how can I make it work faster?
Stephen Woodbridge woodbri at swoodbridge.com
Wed Aug 3 16:02:48 EDT 2011
On 8/3/2011 3:43 PM, Martin Lee wrote:
> On Wed, Aug 3, 2011 at 2:39 PM, Daniel Kastl <daniel at georepublic.de
> <mailto:daniel at georepublic.de>> wrote:
>     On Wed, Aug 3, 2011 at 9:03 PM, Martin Lee <martinchlee at gmail.com
>     <mailto:martinchlee at gmail.com>> wrote:
>         [Small note: The author of this question is familiar with
>         PostGIS, but is not familiar with C language]
>         I have a 'ways' table in PostGIS consisting of about 90,000
>         ways. When I do a pgRouting shortest path query it takes about
>         2,5 seconds to get the result.
>     This is really not many ways. It should be a lot faster.
>       * Did you check your tables have indices?
> All the tables have indices. Are there any special requirements to
> particular tables to have indices?
>       * Do you use bounding boxes not to load all the data (but in your
>         case it's such a small number of ways that even loading all
>         shouldn't take long.)
>         I was pretty unsatisfied with it (I would like it to be about 1
>         second for my imagined user) so I tried to do a 'select * from
>         ways' query in psql with \timing enabled. It took 3 seconds to
>         respond. When I did 'select name, length, x1, y1, x2, y2 from
>         ways' (that is all needed to build a graph in my opinion) it
>         took even more - 4 seconds to respond.
>         Based on that, I assume that pgRouting's SQL queries are somehow
>         optimized.
>         The questions:
>         1. Is it possible to improve the speed of pgRouting queries?
>     The bottleneck is the number of ways you select from the table.
>     You can improve your speed by selecting less road links.
> I am sorry, but I don't really understand what 'road links' mean in
> pgRouting parlance. There are vertices which are built from OSM nodes,
> there are ways which are extracted from OSM multi-line ways. How road
> links are represented and in which table?
Routing problems are abstracted into graph theory concepts:
NODES or VERTICES
Roadways need to be "noded" which means that roadways the cross one
another and intersect need to have a node or vertex at the intersection
point and the roadsways need to be split at that intersection. This is
pretty normal for most data but it is common for data to be not noded. I
suspect that your data is fine in this regard.
EDGES or ROAD SEGMENTS or ROAD LINKS
these are the polylines that connect two NODES.
>     Anything else (like routing algorithms for example) might affect
>     calculation time, but this is only very little compared to the data
>     volume to load.
>     One thing you could check is how your way ID's look like. Lower ID's
>     are better, so you may want to renumber them if there are large ID's
>     and large gaps between them. You can create a new id attribute for that.
> Is the column name 'gid'? By the way, why is it called 'gid' and not 'id'?
This is a postgis-ism, gid means geometry id, it is added when
shapefiles are imported and it is typically an integer of bigint serial
column and is the table primary key. id often conflicts with an existing
column name. gid is dynamically added on data import and stripped off on
data export.
-Steve W
>     Daniel
>         2. How is the actual shortest path calculation done? Is it
>         anything like the following:
>         - Load the whole ways/edges table into memory with one 'select *
>         from ways';
>         - Build a graph from that;
>         - Apply a C-based shortest path algorithm to the graph;
>         - Return a result into psql server?
>         Can any of these steps be improved anyhow?
>         Thank you!
>         _______________________________________________
>         Pgrouting-users mailing list
>         Pgrouting-users at lists.osgeo.org
>         <mailto:Pgrouting-users at lists.osgeo.org>
>         http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>     Georepublic UG & Georepublic Japan
>     eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
>     Web: http://georepublic.de <http://georepublic.de/>
>     Pgrouting-users at lists.osgeo.org <mailto:Pgrouting-users at lists.osgeo.org>
More information about the Pgrouting-users mailing list
