[pgrouting-users] Complilation Errors on Tps and Disjkstra
Daniel Kastl
daniel at georepublic.de
Wed Aug 3 22:06:04 EDT 2011
Hi Jules,
Do you have GAUL library installed? It's required for TSP.
Otherwise, is there a reason not to use packages from here:
http://wiki.osgeo.org/wiki/Enterprise_Linux_GIS
This would save you a lot of time and also makes it easier to remove and
upgrade.
Daniel
On Thu, Aug 4, 2011 at 1:28 AM, Jules Kouadio <sekedoua at gmail.com> wrote:
> Hi.
> I've always the same errors after the make install
> make install
> [ 8%] Building C object extra/tsp/src/CMakeFiles/routing_tsp.dir/tsp.o
> In file included from /home/sekedoua/pgrouting/extra/tsp/src/tsp.h:25,
> from /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:22:
> /home/sekedoua/pgrouting/extra/tsp/src/postgres.h:477: erreur: expected
> ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘bool’
> Dans le fichier inclus à partir de
> /usr/local/pgsql/include/server/catalog/pg_attribute.h:22,
> à partir de /usr/local/pgsql/include/server/access/tupdesc.h:18,
> à partir de /usr/local/pgsql/include/server/utils/relcache.h:17,
> à partir de /usr/local/pgsql/include/server/access/genam.h:22,
> à partir de /usr/local/pgsql/include/server/nodes/execnodes.h:17,
> à partir de
> /usr/local/pgsql/include/server/executor/execdesc.h:18,
> à partir de /usr/local/pgsql/include/server/utils/portal.h:49,
> à partir de /usr/local/pgsql/include/server/executor/spi.h:17,
> à partir de /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:25:
> /usr/local/pgsql/include/server/catalog/genbki.h:23:1: attention : «
> CATALOG » redéfini
> à partir de /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:22:
> /home/sekedoua/pgrouting/extra/tsp/src/postgres.h:537:1: attention : ceci
> est la localisation d'une précédente définition
> from /usr/local/pgsql/include/server/access/tupdesc.h:18,
> from /usr/local/pgsql/include/server/utils/relcache.h:17,
> from /usr/local/pgsql/include/server/access/genam.h:22,
> from /usr/local/pgsql/include/server/nodes/execnodes.h:17,
> from
> from /usr/local/pgsql/include/server/utils/portal.h:49,
> from /usr/local/pgsql/include/server/executor/spi.h:17,
> from /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:25:
> /usr/local/pgsql/include/server/catalog/genbki.h:39: erreur: redefinition
> of typedef ‘aclitem’
> /home/sekedoua/pgrouting/extra/tsp/src/postgres.h:550: erreur: previous
> declaration of ‘aclitem’ was here
> make[2]: *** [extra/tsp/src/CMakeFiles/routing_tsp.dir/tsp.o] Erreur 1
> make[1]: *** [extra/tsp/src/CMakeFiles/routing_tsp.dir/all] Erreur 2
> make: *** [all] Erreur 2
> 2011/7/30 Stephen Woodbridge <woodbri at swoodbridge.com>
>> Your first error is most likely the issue. The build system can not find
>> postgres.h which is the postgresql development header file. You need to
>> install the postgresql development files to build pgRouting. So you might
>> need to do something like:
>> sudo yum install postgresql-devel
>> You need to make sure you all the dependencies installed.
>> -Steve
>> On 7/30/2011 6:18 AM, Jules Kouadio wrote:
>>> Hi everybody
>>> On CentOs 5 (french version).
>>> Why all this errors after the "make install" for Tps and dijkstra?
>>> Can someone help me ?
>>> Thanks !
>>> ERROR [root at bnetd pgrouting]# make install
>>> [ 8%] Building C object extra/tsp/src/CMakeFiles/**routing_tsp.dir/tsp.o
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:22:
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.h:25:22: erreur: postgres.h
>>> : Aucun fichier ou répertoire de ce type Dans le fichier inclus à
>>> partir de /home/sekedoua/pgrouting/**extra/tsp/src/tsp.h:26, à partir de
>>> /home/sekedoua/pgrouting/core/**src/dijkstra.h:25:22: erreur: postgres.h
>>> : Aucun fichier ou répertoire de ce type In file included from
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.h:26, from
>>> /home/sekedoua/pgrouting/core/**src/dijkstra.h:32: erreur: expected
>>> specifier-qualifier-list before ‘float8’
>>> /home/sekedoua/pgrouting/core/**src/dijkstra.h:40: erreur: expected
>>> /home/sekedoua/pgrouting/core/**src/dijkstra.h:47: erreur: expected
>>> declaration specifiers or ‘...’ before ‘bool’
>>> declaration specifiers or ‘...’ before ‘bool’ In file included from
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.h:31: erreur: expected
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:25:26: erreur:
>>> executor/spi.h : Aucun fichier ou répertoire de ce type
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:26:21: erreur: funcapi.h
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:27:29: erreur:
>>> catalog/pg_type.h : Aucun fichier ou répertoire de ce type
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:32:18: erreur: fmgr.h :
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:73: erreur: expected ‘=’,
>>> ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘tsp’
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:98: erreur: expected ‘)’
>>> before ‘*’ token /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c: In
>>> function ‘finish’: /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:111:
>>> erreur: ‘SPI_OK_FINISH’ undeclared (first use in this function)
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:111: erreur: (Each
>>> undeclared identifier is reported only once
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:111: erreur: for each
>>> function it appears in.)
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:113: erreur: ‘ERROR’
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c: Hors de toute fonction :
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:123: erreur: expected
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:129: erreur: expected ‘)’
>>> before ‘*’ token /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:152:
>>> erreur: expected ‘)’ before ‘*’ token
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c: In function ‘solve_tsp’:
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:194: erreur: ‘Portal’
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:194: erreur: expected ‘;’
>>> before ‘SPIportal’ /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:195:
>>> erreur: ‘bool’ undeclared (first use in this function)
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:195: erreur: expected ‘;’
>>> before ‘moredata’ /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:202:
>>> erreur: unknown field ‘x’ specified in initializer
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:202: attention : éléments
>>> en excès dans l'initialisation de la structure
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:202: attention : (near
>>> initialization for ‘point_columns’)
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:202: erreur: unknown
>>> field ‘y’ specified in initializer
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:228: erreur: ‘ERROR’
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:238: erreur:
>>> ‘SPI_OK_CONNECT’ undeclared (first use in this function)
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:244: attention :
>>> assignment makes pointer from integer without a cast
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:252: erreur: ‘SPIportal’
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:252: erreur: ‘true’
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:261: erreur: ‘moredata’
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:261: erreur: ‘TRUE’
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:267: erreur:
>>> ‘SPI_tuptable’ undeclared (first use in this function)
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:271: erreur:
>>> ‘SPI_processed’ undeclared (first use in this function)
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:278: attention :
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:280: attention :
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:291: erreur:
>>> ‘SPITupleTable’ undeclared (first use in this function)
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:291: erreur: ‘tuptable’
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:292: erreur: ‘TupleDesc’
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:292: erreur: expected ‘;’
>>> before ‘tupdesc’ /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:298:
>>> erreur: ‘HeapTuple’ undeclared (first use in this function)
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:298: erreur: expected ‘;’
>>> before ‘tuple’ /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:300:
>>> erreur: ‘tuple’ undeclared (first use in this function)
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:300: erreur: ‘tupdesc’
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:309: erreur: ‘FALSE’
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:325: erreur: ‘point_t’
>>> has no member named ‘x’
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:326: erreur: ‘point_t’
>>> has no member named ‘y’
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:364: erreur:
>>> ‘ERRCODE_E_R_E_CONTAINING_SQL_**NOT_PERMITTED’ undeclared (first use in
>>> this function) /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c: Hors de
>>> toute fonction : /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:370:
>>> attention : la définition de données n'a pas de type ni de classe de
>>> stockage /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:370: attention :
>>> noms de paramètres (sans type) dans la déclaration de fonction
>>> /home/sekedoua/pgrouting/**extra/tsp/src/tsp.c:372: erreur: expected
>>> ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘tsp’ make[2]: ***
>>> [extra/tsp/src/CMakeFiles/**routing_tsp.dir/tsp.o] Erreur 1 make[1]: ***
>>> [extra/tsp/src/CMakeFiles/**routing_tsp.dir/all] Erreur 2 make: ***
>>> 2011/7/29, Ricardo Bayley<ricardo.bayley at gmail.**com<ricardo.bayley at gmail.com>
>>>> Hi folks,
>>>> On the pgRouting website, it says that the latest compiled windows
>>>> binaries
>>>> are for pg8.4.2
>>>> Is this strictily for 8.4.2 or for all the 8.4.x series ?
>>>> best regards
>>>> Ricardo
>> ______________________________**_________________
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
>> http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110804/64c24d58/attachment.html
More information about the Pgrouting-users
