[pgrouting-users] error on routing_dd.sql
Jules Kouadio
sekedoua at gmail.com
Wed Aug 17 06:53:14 EDT 2011
Sorry but i get always the same error.
Thanks
2011/8/16 Stephen Woodbridge <woodbri at swoodbridge.com>
> On 8/16/2011 11:36 AM, Jules Kouadio wrote:
>> Hi . Can someone help me ?
>> When i execute :
>> psql -f /usr/share/pgrouting/routing_**dd.sql routing
>> I get this error :
>> psql:/usr/share/pgrouting/**routing_dd.sql:27:
>> ERROR: could not load library "/ usr / lib / pgsql / librouting_dd.so"
>> libCGAL.so.2: Failed address (mapping) segement of the shared object:
>> Permission denied
> This sounds like the permissions or ownership issues on the file and need
> to set them correctly. On my Debian Lenny system I have:
> woodbri at mappy:/u/www/html/**routing/leaddog$ locate libCGAL
> /usr/lib/libCGAL.a
> /usr/lib/libCGAL.so
> /usr/lib/libCGAL.so.1
> /usr/lib/libCGAL.so.1.0.1
> /usr/lib/libCGAL.so.2
> /usr/lib/libCGAL.so.2.0.1
> /usr/lib/libCGALPDB.a
> /usr/lib/libCGALPDB.so
> /usr/lib/libCGALPDB.so.2
> /usr/lib/libCGALPDB.so.2.0.1
> /usr/lib/libCGALQt.a
> /usr/lib/libCGALQt.so
> /usr/lib/libCGALQt.so.2
> /usr/lib/libCGALQt.so.2.0.1
> /usr/lib/libCGALcore++.a
> /usr/lib/libCGALcore++.so
> /usr/lib/libCGALcore++.so.2
> /usr/lib/libCGALcore++.so.2.0.**1
> /usr/lib/libCGALimageIO.a
> /usr/lib/libCGALimageIO.so
> /usr/lib/libCGALimageIO.so.2
> /usr/lib/libCGALimageIO.so.2.**0.1
> woodbri at mappy:/u/www/html/**routing/leaddog$ ls -l /usr/lib/libCGAL.so*
> lrwxrwxrwx 1 root root 16 2009-03-24 19:34 /usr/lib/libCGAL.so ->
> libCGAL.so.2.0.1
> lrwxrwxrwx 1 root root 16 2007-11-25 18:19 /usr/lib/libCGAL.so.1 ->
> libCGAL.so.1.0.1
> -rw-r--r-- 1 root root 173672 2007-03-25 17:03 /usr/lib/libCGAL.so.1.0.1
> lrwxrwxrwx 1 root root 16 2009-03-24 19:34 /usr/lib/libCGAL.so.2 ->
> libCGAL.so.2.0.1
> -rw-r--r-- 1 root root 215664 2008-06-23 08:02 /usr/lib/libCGAL.so.2.0.1
> You should have something similar. You might try something like:
> sudo chown root.root /usr/lib/libCGAL.so*
> sudo chmod 644 /usr/lib/libCGAL.so.2.0.1
> sudo ldconfig
> or:
> su
> ldconfig
> exit
> -Steve W
> Note : all is wright for
>> /usr/share/pgrouting/routing_**core.sql
>> /usr/share/pgrouting/routing_**core_wrappers.sql
>> /usr/share/pgrouting/routing_**topology.sql
>> /usr/share/pgrouting/matching.**sql
>> /usr/lib/pgsql/librouting_tsp.**so
>> /usr/share/pgrouting/routing_**tsp.sql
>> /usr/share/pgrouting/routing_**tsp_wrappers.sql
>> Thanks .
>> ______________________________**_________________
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
>> http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110817/ce7ccf76/attachment.html
More information about the Pgrouting-users
