[pgrouting-users] error on routing_dd.sql
Daniel Kastl daniel at georepublic.de
Wed Aug 17 07:04:10 EDT 2011
Hi Jules,
Can you make sure that CGAL is installed at the right place?
If you have compiled pgRouting yourself, which OS and architecture do you
use?
Daniel
On Wed, Aug 17, 2011 at 7:53 PM, Jules Kouadio <sekedoua at gmail.com> wrote:
> Sorry but i get always the same error.
> Thanks
> 2011/8/16 Stephen Woodbridge <woodbri at swoodbridge.com>
>> On 8/16/2011 11:36 AM, Jules Kouadio wrote:
>>> Hi . Can someone help me ?
>>> When i execute :
>>> psql -f /usr/share/pgrouting/routing_**dd.sql routing
>>> I get this error :
>>> psql:/usr/share/pgrouting/**routing_dd.sql:27:
>>> ERROR: could not load library "/ usr / lib / pgsql / librouting_dd.so"
>>> libCGAL.so.2: Failed address (mapping) segement of the shared object:
>>> Permission denied
>> This sounds like the permissions or ownership issues on the file and need
>> to set them correctly. On my Debian Lenny system I have:
>> woodbri at mappy:/u/www/html/**routing/leaddog$ locate libCGAL
>> /usr/lib/libCGAL.a
>> /usr/lib/libCGAL.so
>> /usr/lib/libCGAL.so.1
>> /usr/lib/libCGAL.so.1.0.1
>> /usr/lib/libCGAL.so.2
>> /usr/lib/libCGAL.so.2.0.1
>> /usr/lib/libCGALPDB.a
>> /usr/lib/libCGALPDB.so
>> /usr/lib/libCGALPDB.so.2
>> /usr/lib/libCGALPDB.so.2.0.1
>> /usr/lib/libCGALQt.a
>> /usr/lib/libCGALQt.so
>> /usr/lib/libCGALQt.so.2
>> /usr/lib/libCGALQt.so.2.0.1
>> /usr/lib/libCGALcore++.a
>> /usr/lib/libCGALcore++.so
>> /usr/lib/libCGALcore++.so.2
>> /usr/lib/libCGALcore++.so.2.0.**1
>> /usr/lib/libCGALimageIO.a
>> /usr/lib/libCGALimageIO.so
>> /usr/lib/libCGALimageIO.so.2
>> /usr/lib/libCGALimageIO.so.2.**0.1
>> woodbri at mappy:/u/www/html/**routing/leaddog$ ls -l /usr/lib/libCGAL.so*
>> lrwxrwxrwx 1 root root     16 2009-03-24 19:34 /usr/lib/libCGAL.so ->
>> libCGAL.so.2.0.1
>> lrwxrwxrwx 1 root root     16 2007-11-25 18:19 /usr/lib/libCGAL.so.1 ->
>> libCGAL.so.1.0.1
>> -rw-r--r-- 1 root root 173672 2007-03-25 17:03 /usr/lib/libCGAL.so.1.0.1
>> lrwxrwxrwx 1 root root     16 2009-03-24 19:34 /usr/lib/libCGAL.so.2 ->
>> libCGAL.so.2.0.1
>> -rw-r--r-- 1 root root 215664 2008-06-23 08:02 /usr/lib/libCGAL.so.2.0.1
>> You should have something similar. You might try something like:
>> sudo chown root.root /usr/lib/libCGAL.so*
>> sudo chmod 644 /usr/lib/libCGAL.so.2.0.1
>> sudo ldconfig
>> or:
>> su
>> ldconfig
>> exit
>> -Steve W
>>  Note : all is wright for
>>>  /usr/share/pgrouting/routing_**core.sql
>>>  /usr/share/pgrouting/routing_**core_wrappers.sql
>>> /usr/share/pgrouting/routing_**topology.sql
>>> /usr/share/pgrouting/matching.**sql
>>> /usr/lib/pgsql/librouting_tsp.**so
>>> /usr/share/pgrouting/routing_**tsp.sql
>>> /usr/share/pgrouting/routing_**tsp_wrappers.sql
>>> Thanks .
>>> ______________________________**_________________
>>> Pgrouting-users mailing list
>>> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
>>> http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110817/e564ea38/attachment.html
More information about the Pgrouting-users mailing list
