[pgrouting-users] error on routing_dd.sql
Jules Kouadio sekedoua at gmail.com
Wed Aug 17 07:50:16 EDT 2011
I have compile it myself.
Centos 5. 5 (Linux version 2.6.18-238.19.1.el5 (
mockbuild at builder10.centos.org) (gcc version 4.1.2 20080704 (Red Hat
4.1.2-50))
2011/8/17 Daniel Kastl <daniel at georepublic.de>
> Hi Jules,
> Can you make sure that CGAL is installed at the right place?
> If you have compiled pgRouting yourself, which OS and architecture do you
> use?
> Daniel
> On Wed, Aug 17, 2011 at 7:53 PM, Jules Kouadio <sekedoua at gmail.com> wrote:
>> Sorry but i get always the same error.
>> Thanks
>> 2011/8/16 Stephen Woodbridge <woodbri at swoodbridge.com>
>>> On 8/16/2011 11:36 AM, Jules Kouadio wrote:
>>>> Hi . Can someone help me ?
>>>> When i execute :
>>>> psql -f /usr/share/pgrouting/routing_**dd.sql routing
>>>> I get this error :
>>>> psql:/usr/share/pgrouting/**routing_dd.sql:27:
>>>> ERROR: could not load library "/ usr / lib / pgsql / librouting_dd.so"
>>>> libCGAL.so.2: Failed address (mapping) segement of the shared object:
>>>> Permission denied
>>> This sounds like the permissions or ownership issues on the file and need
>>> to set them correctly. On my Debian Lenny system I have:
>>> woodbri at mappy:/u/www/html/**routing/leaddog$ locate libCGAL
>>> /usr/lib/libCGAL.a
>>> /usr/lib/libCGAL.so
>>> /usr/lib/libCGAL.so.1
>>> /usr/lib/libCGAL.so.1.0.1
>>> /usr/lib/libCGAL.so.2
>>> /usr/lib/libCGAL.so.2.0.1
>>> /usr/lib/libCGALPDB.a
>>> /usr/lib/libCGALPDB.so
>>> /usr/lib/libCGALPDB.so.2
>>> /usr/lib/libCGALPDB.so.2.0.1
>>> /usr/lib/libCGALQt.a
>>> /usr/lib/libCGALQt.so
>>> /usr/lib/libCGALQt.so.2
>>> /usr/lib/libCGALQt.so.2.0.1
>>> /usr/lib/libCGALcore++.a
>>> /usr/lib/libCGALcore++.so
>>> /usr/lib/libCGALcore++.so.2
>>> /usr/lib/libCGALcore++.so.2.0.**1
>>> /usr/lib/libCGALimageIO.a
>>> /usr/lib/libCGALimageIO.so
>>> /usr/lib/libCGALimageIO.so.2
>>> /usr/lib/libCGALimageIO.so.2.**0.1
>>> woodbri at mappy:/u/www/html/**routing/leaddog$ ls -l /usr/lib/libCGAL.so*
>>> lrwxrwxrwx 1 root root     16 2009-03-24 19:34 /usr/lib/libCGAL.so ->
>>> libCGAL.so.2.0.1
>>> lrwxrwxrwx 1 root root     16 2007-11-25 18:19 /usr/lib/libCGAL.so.1 ->
>>> libCGAL.so.1.0.1
>>> -rw-r--r-- 1 root root 173672 2007-03-25 17:03 /usr/lib/libCGAL.so.1.0.1
>>> lrwxrwxrwx 1 root root     16 2009-03-24 19:34 /usr/lib/libCGAL.so.2 ->
>>> libCGAL.so.2.0.1
>>> -rw-r--r-- 1 root root 215664 2008-06-23 08:02 /usr/lib/libCGAL.so.2.0.1
>>> You should have something similar. You might try something like:
>>> sudo chown root.root /usr/lib/libCGAL.so*
>>> sudo chmod 644 /usr/lib/libCGAL.so.2.0.1
>>> sudo ldconfig
>>> or:
>>> su
>>> ldconfig
>>> exit
>>> -Steve W
>>>  Note : all is wright for
>>>>  /usr/share/pgrouting/routing_**core.sql
>>>>  /usr/share/pgrouting/routing_**core_wrappers.sql
>>>> /usr/share/pgrouting/routing_**topology.sql
>>>> /usr/share/pgrouting/matching.**sql
>>>> /usr/lib/pgsql/librouting_tsp.**so
>>>> /usr/share/pgrouting/routing_**tsp.sql
>>>> /usr/share/pgrouting/routing_**tsp_wrappers.sql
>>>> Thanks .
>>>> ______________________________**_________________
>>>> Pgrouting-users mailing list
>>>> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
>>>> http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110817/4f4c8d0c/attachment-0001.html
More information about the Pgrouting-users mailing list
