[pgrouting-users] error on routing_dd.sql
Daniel Kastl daniel at georepublic.de
Wed Aug 17 07:55:15 EDT 2011
You could also try the package of the ELGIS repository:
http://elgis.argeo.org/
And if you want to compile yourself, take a look into the .spec file that is
inside the .src package:
http://elgis.argeo.org/repos/testing/5/elgis/SRPMS/repoview/pgrouting.html
Hope that helps,
Daniel
On Wed, Aug 17, 2011 at 8:50 PM, Jules Kouadio <sekedoua at gmail.com> wrote:
> I have compile it myself.
> Centos 5. 5 (Linux version 2.6.18-238.19.1.el5 (
> mockbuild at builder10.centos.org) (gcc version 4.1.2 20080704 (Red Hat
> 4.1.2-50))
> 2011/8/17 Daniel Kastl <daniel at georepublic.de>
>> Hi Jules,
>> Can you make sure that CGAL is installed at the right place?
>> If you have compiled pgRouting yourself, which OS and architecture do you
>> use?
>> Daniel
>> On Wed, Aug 17, 2011 at 7:53 PM, Jules Kouadio <sekedoua at gmail.com>wrote:
>>> Sorry but i get always the same error.
>>> Thanks
>>> 2011/8/16 Stephen Woodbridge <woodbri at swoodbridge.com>
>>>> On 8/16/2011 11:36 AM, Jules Kouadio wrote:
>>>>> Hi . Can someone help me ?
>>>>> When i execute :
>>>>> psql -f /usr/share/pgrouting/routing_**dd.sql routing
>>>>> I get this error :
>>>>> psql:/usr/share/pgrouting/**routing_dd.sql:27:
>>>>> ERROR: could not load library "/ usr / lib / pgsql / librouting_dd.so"
>>>>> libCGAL.so.2: Failed address (mapping) segement of the shared object:
>>>>> Permission denied
>>>> This sounds like the permissions or ownership issues on the file and
>>>> need to set them correctly. On my Debian Lenny system I have:
>>>> woodbri at mappy:/u/www/html/**routing/leaddog$ locate libCGAL
>>>> /usr/lib/libCGAL.a
>>>> /usr/lib/libCGAL.so
>>>> /usr/lib/libCGAL.so.1
>>>> /usr/lib/libCGAL.so.1.0.1
>>>> /usr/lib/libCGAL.so.2
>>>> /usr/lib/libCGAL.so.2.0.1
>>>> /usr/lib/libCGALPDB.a
>>>> /usr/lib/libCGALPDB.so
>>>> /usr/lib/libCGALPDB.so.2
>>>> /usr/lib/libCGALPDB.so.2.0.1
>>>> /usr/lib/libCGALQt.a
>>>> /usr/lib/libCGALQt.so
>>>> /usr/lib/libCGALQt.so.2
>>>> /usr/lib/libCGALQt.so.2.0.1
>>>> /usr/lib/libCGALcore++.a
>>>> /usr/lib/libCGALcore++.so
>>>> /usr/lib/libCGALcore++.so.2
>>>> /usr/lib/libCGALcore++.so.2.0.**1
>>>> /usr/lib/libCGALimageIO.a
>>>> /usr/lib/libCGALimageIO.so
>>>> /usr/lib/libCGALimageIO.so.2
>>>> /usr/lib/libCGALimageIO.so.2.**0.1
>>>> woodbri at mappy:/u/www/html/**routing/leaddog$ ls -l /usr/lib/libCGAL.so*
>>>> lrwxrwxrwx 1 root root     16 2009-03-24 19:34 /usr/lib/libCGAL.so ->
>>>> libCGAL.so.2.0.1
>>>> lrwxrwxrwx 1 root root     16 2007-11-25 18:19 /usr/lib/libCGAL.so.1 ->
>>>> libCGAL.so.1.0.1
>>>> -rw-r--r-- 1 root root 173672 2007-03-25 17:03 /usr/lib/libCGAL.so.1.0.1
>>>> lrwxrwxrwx 1 root root     16 2009-03-24 19:34 /usr/lib/libCGAL.so.2 ->
>>>> libCGAL.so.2.0.1
>>>> -rw-r--r-- 1 root root 215664 2008-06-23 08:02 /usr/lib/libCGAL.so.2.0.1
>>>> You should have something similar. You might try something like:
>>>> sudo chown root.root /usr/lib/libCGAL.so*
>>>> sudo chmod 644 /usr/lib/libCGAL.so.2.0.1
>>>> sudo ldconfig
>>>> or:
>>>> su
>>>> ldconfig
>>>> exit
>>>> -Steve W
>>>>  Note : all is wright for
>>>>>  /usr/share/pgrouting/routing_**core.sql
>>>>>  /usr/share/pgrouting/routing_**core_wrappers.sql
>>>>> /usr/share/pgrouting/routing_**topology.sql
>>>>> /usr/share/pgrouting/matching.**sql
>>>>> /usr/lib/pgsql/librouting_tsp.**so
>>>>> /usr/share/pgrouting/routing_**tsp.sql
>>>>> /usr/share/pgrouting/routing_**tsp_wrappers.sql
>>>>> Thanks .
>>>>> ______________________________**_________________
>>>>> Pgrouting-users mailing list
>>>>> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
>>>>> http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de
>> Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110817/5f5813b3/attachment.html
More information about the Pgrouting-users mailing list
