[pgrouting-users] error on routing_dd.sql
Jules Kouadio sekedoua at gmail.com
Wed Aug 17 11:20:11 EDT 2011
Thanks Daniel
How can I know that pgrouting is correctly inslalled
Jules ?
2011/8/17 Daniel Kastl <daniel at georepublic.de>
> You could also try the package of the ELGIS repository:
> http://elgis.argeo.org/
> And if you want to compile yourself, take a look into the .spec file that
> is inside the .src package:
> http://elgis.argeo.org/repos/testing/5/elgis/SRPMS/repoview/pgrouting.html
> Hope that helps,
> Daniel
> On Wed, Aug 17, 2011 at 8:50 PM, Jules Kouadio <sekedoua at gmail.com> wrote:
>> I have compile it myself.
>> Centos 5. 5 (Linux version 2.6.18-238.19.1.el5 (
>> mockbuild at builder10.centos.org) (gcc version 4.1.2 20080704 (Red Hat
>> 4.1.2-50))
>>> Hi Jules,
>>> Can you make sure that CGAL is installed at the right place?
>>> If you have compiled pgRouting yourself, which OS and architecture do you
>>> use?
>>> Daniel
>>> On Wed, Aug 17, 2011 at 7:53 PM, Jules Kouadio <sekedoua at gmail.com>wrote:
>>>> Sorry but i get always the same error.
>>>> Thanks
>>>> 2011/8/16 Stephen Woodbridge <woodbri at swoodbridge.com>
>>>>> On 8/16/2011 11:36 AM, Jules Kouadio wrote:
>>>>>> Hi . Can someone help me ?
>>>>>> When i execute :
>>>>>> psql -f /usr/share/pgrouting/routing_**dd.sql routing
>>>>>> I get this error :
>>>>>> psql:/usr/share/pgrouting/**routing_dd.sql:27:
>>>>>> ERROR: could not load library "/ usr / lib / pgsql / librouting_dd.so"
>>>>>> libCGAL.so.2: Failed address (mapping) segement of the shared object:
>>>>>> Permission denied
>>>>> This sounds like the permissions or ownership issues on the file and
>>>>> need to set them correctly. On my Debian Lenny system I have:
>>>>> woodbri at mappy:/u/www/html/**routing/leaddog$ locate libCGAL
>>>>> /usr/lib/libCGAL.a
>>>>> /usr/lib/libCGAL.so
>>>>> /usr/lib/libCGAL.so.1
>>>>> /usr/lib/libCGAL.so.1.0.1
>>>>> /usr/lib/libCGAL.so.2
>>>>> /usr/lib/libCGAL.so.2.0.1
>>>>> /usr/lib/libCGALPDB.a
>>>>> /usr/lib/libCGALPDB.so
>>>>> /usr/lib/libCGALPDB.so.2
>>>>> /usr/lib/libCGALPDB.so.2.0.1
>>>>> /usr/lib/libCGALQt.a
>>>>> /usr/lib/libCGALQt.so
>>>>> /usr/lib/libCGALQt.so.2
>>>>> /usr/lib/libCGALQt.so.2.0.1
>>>>> /usr/lib/libCGALcore++.a
>>>>> /usr/lib/libCGALcore++.so
>>>>> /usr/lib/libCGALcore++.so.2
>>>>> /usr/lib/libCGALcore++.so.2.0.**1
>>>>> /usr/lib/libCGALimageIO.a
>>>>> /usr/lib/libCGALimageIO.so
>>>>> /usr/lib/libCGALimageIO.so.2
>>>>> /usr/lib/libCGALimageIO.so.2.**0.1
>>>>> woodbri at mappy:/u/www/html/**routing/leaddog$ ls -l
>>>>> /usr/lib/libCGAL.so*
>>>>> lrwxrwxrwx 1 root root     16 2009-03-24 19:34 /usr/lib/libCGAL.so ->
>>>>> libCGAL.so.2.0.1
>>>>> lrwxrwxrwx 1 root root     16 2007-11-25 18:19 /usr/lib/libCGAL.so.1 ->
>>>>> libCGAL.so.1.0.1
>>>>> -rw-r--r-- 1 root root 173672 2007-03-25 17:03
>>>>> lrwxrwxrwx 1 root root     16 2009-03-24 19:34 /usr/lib/libCGAL.so.2 ->
>>>>> libCGAL.so.2.0.1
>>>>> -rw-r--r-- 1 root root 215664 2008-06-23 08:02
>>>>> You should have something similar. You might try something like:
>>>>> sudo chown root.root /usr/lib/libCGAL.so*
>>>>> sudo chmod 644 /usr/lib/libCGAL.so.2.0.1
>>>>> sudo ldconfig
>>>>> or:
>>>>> su
>>>>> ldconfig
>>>>> exit
>>>>> -Steve W
>>>>>  Note : all is wright for
>>>>>>  /usr/share/pgrouting/routing_**core.sql
>>>>>>  /usr/share/pgrouting/routing_**core_wrappers.sql
>>>>>> /usr/share/pgrouting/routing_**topology.sql
>>>>>> /usr/share/pgrouting/matching.**sql
>>>>>> /usr/lib/pgsql/librouting_tsp.**so
>>>>>> /usr/share/pgrouting/routing_**tsp.sql
>>>>>> /usr/share/pgrouting/routing_**tsp_wrappers.sql
>>>>>> Thanks .
>>>>>> ______________________________**_________________
>>>>>> Pgrouting-users mailing list
>>>>>> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
>>>>>> http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
>>>> _______________________________________________
>>> Georepublic UG & Georepublic Japan
>>> eMail: daniel.kastl at georepublic.de
>>> Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110817/34e10d50/attachment-0001.html
More information about the Pgrouting-users mailing list
