[pgrouting-users] error on routing_dd.sql
Jules Kouadio
sekedoua at gmail.com
Thu Aug 18 03:49:07 EDT 2011
Hi daniel.
Can I know how to ru this file ?, I'm a new linux user.
Thanks.
2011/8/17 Daniel Kastl <daniel at georepublic.de>
> Hi Jules,
> First of all you shouldn't get errors when loading the pgRouting functions.
> This here is a script to make a PostGIS and based on that a pgRouting
> template database:
> https://github.com/pgRouting/workshop/blob/master/bin/create_templates.sh
> It's only tested on Ubuntu, so on CentOS you might have to adjust the paths
> at the beginning.
> And you can remove the "--quiet" flags to be able to read the full console
> log.
> Daniel
> On Thu, Aug 18, 2011 at 12:20 AM, Jules Kouadio <sekedoua at gmail.com>wrote:
>> Thanks Daniel
>> How can I know that pgrouting is correctly inslalled
>> Jules ?
>>> You could also try the package of the ELGIS repository:
>>> http://elgis.argeo.org/
>>> And if you want to compile yourself, take a look into the .spec file that
>>> is inside the .src package:
>>> http://elgis.argeo.org/repos/testing/5/elgis/SRPMS/repoview/pgrouting.html
>>> Hope that helps,
>>> Daniel
>>> On Wed, Aug 17, 2011 at 8:50 PM, Jules Kouadio <sekedoua at gmail.com>wrote:
>>>> I have compile it myself.
>>>> Centos 5. 5 (Linux version 2.6.18-238.19.1.el5 (
>>>> mockbuild at builder10.centos.org) (gcc version 4.1.2 20080704 (Red Hat
>>>> 4.1.2-50))
>>>>> Hi Jules,
>>>>> Can you make sure that CGAL is installed at the right place?
>>>>> If you have compiled pgRouting yourself, which OS and architecture do
>>>>> you use?
>>>>> Daniel
>>>>> On Wed, Aug 17, 2011 at 7:53 PM, Jules Kouadio <sekedoua at gmail.com>wrote:
>>>>>> Sorry but i get always the same error.
>>>>>> Thanks
>>>>>> 2011/8/16 Stephen Woodbridge <woodbri at swoodbridge.com>
>>>>>>> On 8/16/2011 11:36 AM, Jules Kouadio wrote:
>>>>>>>> Hi . Can someone help me ?
>>>>>>>> When i execute :
>>>>>>>> psql -f /usr/share/pgrouting/routing_**dd.sql routing
>>>>>>>> I get this error :
>>>>>>>> psql:/usr/share/pgrouting/**routing_dd.sql:27:
>>>>>>>> ERROR: could not load library "/ usr / lib / pgsql /
>>>>>>>> librouting_dd.so"
>>>>>>>> libCGAL.so.2: Failed address (mapping) segement of the shared
>>>>>>>> object:
>>>>>>>> Permission denied
>>>>>>> This sounds like the permissions or ownership issues on the file and
>>>>>>> need to set them correctly. On my Debian Lenny system I have:
>>>>>>> woodbri at mappy:/u/www/html/**routing/leaddog$ locate libCGAL
>>>>>>> /usr/lib/libCGAL.a
>>>>>>> /usr/lib/libCGAL.so
>>>>>>> /usr/lib/libCGAL.so.1
>>>>>>> /usr/lib/libCGAL.so.1.0.1
>>>>>>> /usr/lib/libCGAL.so.2
>>>>>>> /usr/lib/libCGAL.so.2.0.1
>>>>>>> /usr/lib/libCGALPDB.a
>>>>>>> /usr/lib/libCGALPDB.so
>>>>>>> /usr/lib/libCGALPDB.so.2
>>>>>>> /usr/lib/libCGALPDB.so.2.0.1
>>>>>>> /usr/lib/libCGALQt.a
>>>>>>> /usr/lib/libCGALQt.so
>>>>>>> /usr/lib/libCGALQt.so.2
>>>>>>> /usr/lib/libCGALQt.so.2.0.1
>>>>>>> /usr/lib/libCGALcore++.a
>>>>>>> /usr/lib/libCGALcore++.so
>>>>>>> /usr/lib/libCGALcore++.so.2
>>>>>>> /usr/lib/libCGALcore++.so.2.0.**1
>>>>>>> /usr/lib/libCGALimageIO.a
>>>>>>> /usr/lib/libCGALimageIO.so
>>>>>>> /usr/lib/libCGALimageIO.so.2
>>>>>>> /usr/lib/libCGALimageIO.so.2.**0.1
>>>>>>> woodbri at mappy:/u/www/html/**routing/leaddog$ ls -l
>>>>>>> /usr/lib/libCGAL.so*
>>>>>>> lrwxrwxrwx 1 root root 16 2009-03-24 19:34 /usr/lib/libCGAL.so ->
>>>>>>> libCGAL.so.2.0.1
>>>>>>> lrwxrwxrwx 1 root root 16 2007-11-25 18:19 /usr/lib/libCGAL.so.1
>>>>>>> -> libCGAL.so.1.0.1
>>>>>>> -rw-r--r-- 1 root root 173672 2007-03-25 17:03
>>>>>>> lrwxrwxrwx 1 root root 16 2009-03-24 19:34 /usr/lib/libCGAL.so.2
>>>>>>> -> libCGAL.so.2.0.1
>>>>>>> -rw-r--r-- 1 root root 215664 2008-06-23 08:02
>>>>>>> You should have something similar. You might try something like:
>>>>>>> sudo chown root.root /usr/lib/libCGAL.so*
>>>>>>> sudo chmod 644 /usr/lib/libCGAL.so.2.0.1
>>>>>>> sudo ldconfig
>>>>>>> or:
>>>>>>> su
>>>>>>> ldconfig
>>>>>>> exit
>>>>>>> -Steve W
>>>>>>> Note : all is wright for
>>>>>>>> /usr/share/pgrouting/routing_**core.sql
>>>>>>>> /usr/share/pgrouting/routing_**core_wrappers.sql
>>>>>>>> /usr/share/pgrouting/routing_**topology.sql
>>>>>>>> /usr/share/pgrouting/matching.**sql
>>>>>>>> /usr/lib/pgsql/librouting_tsp.**so
>>>>>>>> /usr/share/pgrouting/routing_**tsp.sql
>>>>>>>> /usr/share/pgrouting/routing_**tsp_wrappers.sql
>>>>>>>> Thanks .
>>>>>>>> ______________________________**_________________
>>>>>>>> Pgrouting-users mailing list
>>>>>>>> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
>>>>>>>> http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
>>>>>> _______________________________________________
>>>>> Georepublic UG & Georepublic Japan
>>>>> eMail: daniel.kastl at georepublic.de
>>>>> Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110818/82306e1d/attachment.html
More information about the Pgrouting-users
