[pgrouting-users] routing with one way roads
John Williams jdwilliams1982 at gmail.com
Thu Dec 8 10:46:50 EST 2011
I asked about this a few days ago and Steve mentioned that the shooting
star algorithm for one-ways may be broken on 1.05. I switched to Dijkstra
and everything works fine for me now...
On Thu, Dec 8, 2011 at 9:29 AM, Mehmet Hilmi Elihos <elihos at gmail.com>wrote:
> Hi to all,
> I'm trying to make routing with pg_routing algorithms.
> But i'm ahving problems with one way roads. Algorithm insists on using
> opposite directional roads even i'm using the biggest reverse_cost value.
> Here is the algorithm that i'm using.
> SELECT * FROM shortest_path_shooting_star(
>         'SELECT gid as id, class_id, source, target, length*c.cost as cost,
>                 x1, y1, x2, y2, rule, to_cost, reverse_cost*c.cost as
> reverse_cost
>         FROM ways w, classes c
>         WHERE class_id=c.id', 1450296, 1468993, true, true);
> the algorithm always ignores the reverse_cost and insists on using
> opposite directional roads.
> Could you help me to solve this problem?
> You can find a snap_shot about this problem in the attachment.
> Thanks for your help
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20111208/f9a1c50d/attachment.html
More information about the Pgrouting-users mailing list
