[pgrouting-users] TSP and how to contribute
Daniel Kastl daniel at georepublic.de
Fri Jan 14 03:15:11 EST 2011
2011/1/14 Emre Koc <emrekoch at gmail.com>
> Sure
> Here is my sql query for that image.
> SELECT edges.gid, ST_AsText(edges.the_geom) AS geotext,
>                  edges.ft_minutes,
>  edges.meters
> FROM edges,
> (SELECT edge_id, cost FROM driving_distance('SELECT gid as id,
>  source::integer,
>  target::integer,
>          meters::double precision as cost
>  FROM edges', $startVertexID, $cost,false,false)
> )  as rt
> WHERE edges.gid=rt.edge_id;";
> I just give a sample vertex id and a cost value in meters and got resulting
> edges. Normally when I find shortest paths all roads are connected so the
> graph is ok. But this driving directions does not output connected roads,
> thats the thing I do not understand.
Driving distance returns you all the vertices you can reach from a start
point to within what you have defined as the maximum costs.
I think you're looking for another query (Dijkstra, A-Star, Shooting Star).
The edge column in driving distance doesn't return a "useful" result as I
just answered the day before in this message:
http://lists.osgeo.org/pipermail/pgrouting-users/2011-January/000474.html
Daniel
> /emre
> On Fri, Jan 14, 2011 at 5:26 AM, Daniel Kastl <daniel at georepublic.de>wrote:
>>> I checked driving directions functionality and seems like the feature
>>> that I was looking for. But It returns non connected edges which are close
>>> by a cost. Do you know how does this function really work ? Here is my
>>> screenshot  http://db.tt/0bb62XB. Shouldn't the output be connected ?
>> Could you tell us what you did exactly? The query for example.
>> Daniel
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de
>> Web: http://georepublic.de
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110114/e44fae73/attachment.html
More information about the Pgrouting-users mailing list
