[pgrouting-users] path not found
Stephen Woodbridge woodbri at swoodbridge.com
Thu Jan 20 14:02:32 EST 2011
On 1/20/2011 3:24 AM, Luca Santaniello wrote:
> Hi all,
> I use pgrouting 1.02. I have teleatlas table with cost and reverse cost.
> When I have source cost infinity, my path is not found. Is it normal?
> Why? If I start my path from source with cost not infinity, path is found.
Hi Luca,
Please provide more information, I'm a little confused by your question.
Cost is normally associated with an edge.
What is your source? an edge or a node?
How are you setting the the cost to infinity? what value are you using?
Can you provide the sql query you are using?
Which solution are you trying? dijkstra, astar, or shootingstar?
Thanks,
   -Steve
More information about the Pgrouting-users mailing list
