[pgrouting-users] path not found
Luca Santaniello
luca.santaniello at email.it
Fri Jan 21 05:12:10 EST 2011
Thanks for reply. I'm using shooting_star alghorithm. My cost is associated with an edge. Many edge have 'infinity' cost (update.... set cost = 'infinity'). I definited wrapper function.
I call my function using this sql:
select * from carto_shootingstar('carto_nw', 456824, 450370, 0.1, 'cost_time', 'reverse_cost_time', true, true)
Thanks
[CODE]
DECLARE
geom_table ALIAS FOR $1;
sourceid ALIAS FOR $2;
targetid ALIAS FOR $3;
delta ALIAS FOR $4;
cost_column ALIAS FOR $5;
reverse_cost_column ALIAS FOR $6;
dir ALIAS FOR $7;
rc ALIAS FOR $8;
rec record;
r record;
path_result record;
v_id integer;
e_id integer;
geom geoms;
srid integer;
source_x float8;
source_y float8;
target_x float8;
target_y float8;
ll_x float8;
ll_y float8;
ur_x float8;
ur_y float8;
query text;
id integer;
BEGIN
FOR rec IN EXECUTE
'select srid(the_geom) from ' ||
quote_ident(geom_table) || ' limit 1'
LOOP
END LOOP;
srid := rec.srid;
FOR rec IN EXECUTE
'select x(startpoint(the_geom)) as source_x from ' ||
quote_ident(geom_table) || ' where gid = '||sourceid
LOOP
END LOOP;
source_x := rec.source_x;
FOR rec IN EXECUTE
'select y(startpoint(the_geom)) as source_y from ' ||
quote_ident(geom_table) || ' where gid = ' ||sourceid
LOOP
END LOOP;
source_y := rec.source_y;
FOR rec IN EXECUTE
'select x(startpoint(the_geom)) as target_x from ' ||
quote_ident(geom_table) || ' where gid = ' ||targetid
LOOP
END LOOP;
target_x := rec.target_x;
FOR rec IN EXECUTE
'select y(startpoint(the_geom)) as target_y from ' ||
LOOP
END LOOP;
target_y := rec.target_y;
FOR rec IN EXECUTE 'SELECT CASE WHEN '||source_x||'<'||target_x||
' THEN '||source_x||' ELSE '||target_x||
' END as ll_x, CASE WHEN '||source_x||'>'||target_x||
' THEN '||source_x||' ELSE '||target_x||' END as ur_x'
LOOP
END LOOP;
ll_x := rec.ll_x;
ur_x := rec.ur_x;
FOR rec IN EXECUTE 'SELECT CASE WHEN '||source_y||'<'||
target_y||' THEN '||source_y||' ELSE '||
target_y||' END as ll_y, CASE WHEN '||
source_y||'>'||target_y||' THEN '||
source_y||' ELSE '||target_y||' END as ur_y'
LOOP
END LOOP;
ll_y := rec.ll_y;
ur_y := rec.ur_y;
query := 'SELECT gid, the_geom FROM ' ||
'shortest_path_shooting_star(''SELECT gid as id, source::integer, ' ||
'target::integer, '||cost_column||'::double precision as cost, ' ||
'x1::double precision, y1::double precision, x2::double ' ||
'precision, y2::double precision, rule::varchar, ' ||
'to_cost::double precision ';
IF rc THEN query := query || ' , ' || reverse_cost_column || ' as reverse_cost ';
END IF;
query := query || 'FROM ' || quote_ident(geom_table) || ' where setSRID(''''BOX3D('||
ll_x-delta||' '||ll_y-delta||','||ur_x+delta||' '||
ur_y+delta||')''''::BOX3D, ' || srid || ')&& the_geom'', ' ||
quote_literal(sourceid) || ' , ' ||
quote_literal(targetid) || ' , '''||text(dir)||''', '''||text(rc)||''' ),' ||
quote_ident(geom_table) || ' where edge_id = gid ';
FOR path_result IN EXECUTE query
LOOP
geom.gid := path_result.gid;
geom.the_geom := path_result.the_geom;
geom.id := id;
RETURN NEXT geom;
END LOOP;
RETURN;
END;
[/CODE]
Luca Santaniello
email: luca.santaniello at email.it
phone: +39 3470373994
skype: luca.santaniello
msn: luketto81 at hotmail.com
>> Hi all,
>> I use pgrouting 1.02. I have teleatlas table with cost and reverse cost.
>> When I have source cost infinity, my path is not found. Is it normal?
>> Why? If I start my path from source with cost not infinity, path is
>> found.
> Hi Luca,
> Please provide more information, I'm a little confused by your question.
> Cost is normally associated with an edge.
> What is your source? an edge or a node?
> How are you setting the the cost to infinity? what value are you using?
> Can you provide the sql query you are using?
> Which solution are you trying? dijkstra, astar, or shootingstar?
> Thanks,
> -Steve
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110121/075a90c1/attachment.html
More information about the Pgrouting-users
