[pgrouting-users] Error whilst installing on CentOS 5.5
Richard Willars
richard.willars at lemonstorm.com
Tue Jan 25 06:13:37 EST 2011
Thanks to both of you. I actually already had that rpm installed so tried
downloading postgis90, unfortunately it kicked up with a load of issues
about conflicts so I gave up! I also tried upgrading boost-devel to the
latest version but it didn't seem to think it was still running an old
version even after installation.
Already spent 3 days trying to get it working on CentOS so I've switched to
Debian to see if I have any better luck! Installation went really well right
up to the part of compiling the pgrouting library... I got the following
error:
http://pastie.org/1495628
I was following these instructions:
http://www.gisnotes.com/wordpress/2008/05/installing-postgresql-postgis-pgrouting-on-debian/
As those instructions install postgresql 8.3 I tried both version 1.05 and
1.02 of pgrouting, however both came up with errors.
Any thoughts?
Regards,
Richard
On Tue, Jan 25, 2011 at 1:02 AM, Daniel Kastl <daniel at georepublic.de> wrote:
> It must be something with the Boost version.
> About a year ago users started to complain about this error and it seemed
> that some path related to the "property_map" changed in newer Boost
> versions. After this happened with Ubuntu and FreeBSD ... and I think also
> Debian (don't know exactly), I corrected this according to the patch someone
> sent ... as far as I remember.
> You can find it in the commit message of edge_visitor.hpp for example:
> https://github.com/pgRouting/pgrouting/commits/master/core/src/edge_visitors.hpp
> <https://github.com/pgRouting/pgrouting/commits/master/core/src/edge_visitors.hpp>Sorry,
> but I'm also not so familiar with Git yet and don't know exactly how to get
> the changes of this revisions. But I remember there were a few files where
> the path has changed.
> When you checkout Tag "v1.05" though it's still the previous path and you
> should be able to compile.
> Good to know that there are still distributions with pretty ancient Boost.
> Daniel
> 2011/1/25 Charles Galpin <cgalpin at lhsw.com>
>> I don't think the version os the problem since I am running the same. I
>> don't recall what I did exactly but did run ldconfig at some point. Perhaps
>> run that and try again.
>> However I have since learned about pgrpms and in theory installing postgis
>> should be as simple as
>> rpm -ivh http://yum.pgrpms.org/reporpms/9.0/pgdg-centos-9.0-2.noarch.rpm
>> yum install postgis90
>> This ets the postgres repos setup and then installs postgis and all
>> dependencies from it.
>> There is a remote chance you'd need to
>> edit /etc/yum.repos.d/CentOS-Base.repo [base] and [updates] sections and add
>> exclude=postgresql*
>> This might be worth a try (I have tried this in a fresh VM and it appears
>> to have worked fine but have not attempted to use it yet). Long term this is
>> a much better approach than building from scratch each time (for me). I am
>> not sure if this includes pgrouting, but it's a good start even if not.
>> hth
>> charles
>> On Jan 24, 2011, at 12:07 PM, Richard Willars wrote:
>> Hi Charles,
>> Thanks for the advice. Unfortunately I've already got boost-devel
>> installed (v1.33.1). I can see there's a newer version of boost
>> available (1.45) but it's not available via yum.. if I can work out
>> how to install it I will, but before I spend ages on that do you think
>> that that minor update would fix the issue?
>> Regards,
>> Richard
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110125/a0b00e5a/attachment-0001.html
More information about the Pgrouting-users
