[pgrouting-users] Error whilst installing on CentOS 5.5
Charles Galpin
cgalpin at lhsw.com
Tue Jan 25 08:51:16 EST 2011
I googled for that error and found this fix
http://download.osgeo.org/pgrouting/forum/pgrouting.postlbs.org/ticket/138.html
Not sure what to say about centos. I don't have time to try it right now and wish I had taken notes. It couldn't have been to hard or I would have :)
charles
On Jan 25, 2011, at 6:13 AM, Richard Willars wrote:
> Thanks to both of you. I actually already had that rpm installed so tried downloading postgis90, unfortunately it kicked up with a load of issues about conflicts so I gave up! I also tried upgrading boost-devel to the latest version but it didn't seem to think it was still running an old version even after installation.
> Already spent 3 days trying to get it working on CentOS so I've switched to Debian to see if I have any better luck! Installation went really well right up to the part of compiling the pgrouting library... I got the following error:
> http://pastie.org/1495628
> I was following these instructions: http://www.gisnotes.com/wordpress/2008/05/installing-postgresql-postgis-pgrouting-on-debian/
> As those instructions install postgresql 8.3 I tried both version 1.05 and 1.02 of pgrouting, however both came up with errors.
> Any thoughts?
> Regards,
> Richard
> On Tue, Jan 25, 2011 at 1:02 AM, Daniel Kastl <daniel at georepublic.de> wrote:
> It must be something with the Boost version.
> About a year ago users started to complain about this error and it seemed that some path related to the "property_map" changed in newer Boost versions. After this happened with Ubuntu and FreeBSD ... and I think also Debian (don't know exactly), I corrected this according to the patch someone sent ... as far as I remember.
> You can find it in the commit message of edge_visitor.hpp for example:
> https://github.com/pgRouting/pgrouting/commits/master/core/src/edge_visitors.hpp
> Sorry, but I'm also not so familiar with Git yet and don't know exactly how to get the changes of this revisions. But I remember there were a few files where the path has changed.
> When you checkout Tag "v1.05" though it's still the previous path and you should be able to compile.
> Good to know that there are still distributions with pretty ancient Boost.
> Daniel
> 2011/1/25 Charles Galpin <cgalpin at lhsw.com>
> I don't think the version os the problem since I am running the same. I don't recall what I did exactly but did run ldconfig at some point. Perhaps run that and try again.
> However I have since learned about pgrpms and in theory installing postgis should be as simple as
> rpm -ivh http://yum.pgrpms.org/reporpms/9.0/pgdg-centos-9.0-2.noarch.rpm
> yum install postgis90
> This ets the postgres repos setup and then installs postgis and all dependencies from it.
> There is a remote chance you'd need to edit /etc/yum.repos.d/CentOS-Base.repo [base] and [updates] sections and add
> exclude=postgresql*
> This might be worth a try (I have tried this in a fresh VM and it appears to have worked fine but have not attempted to use it yet). Long term this is a much better approach than building from scratch each time (for me). I am not sure if this includes pgrouting, but it's a good start even if not.
> hth
> charles
> On Jan 24, 2011, at 12:07 PM, Richard Willars wrote:
>> Hi Charles,
>> Thanks for the advice. Unfortunately I've already got boost-devel
>> installed (v1.33.1). I can see there's a newer version of boost
>> available (1.45) but it's not available via yum.. if I can work out
>> how to install it I will, but before I spend ages on that do you think
>> that that minor update would fix the issue?
>> Regards,
>> Richard
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110125/467bff18/attachment.html
More information about the Pgrouting-users
