[pgrouting-users] Table location
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Jan 28 13:00:47 EST 2011
I cloned vertex assignment code to change it for zlevels and it was
trivial to make it run in another schema. I think all you need to do is:
1. remove all the explicit references to "public." from the stored
procedure and reload it in you "data." schema
2. then make sure you set the default db search path like:
alter database mydb set search_path to data, public;
And everything is good.
-Steve
On 1/28/2011 1:39 AM, Dan Putler wrote:
> Given your comment on vertex assignments needing to be done in the
> public schema, I'm now not sure. I may have had a problem with the
> vertex assignments, looked through that code and discovered that it
> didn't handle anything other than the public schema well, and just put
> everything in public after that. I did this in July, so things are on
> the hazy side. What I was working on isn't part of a web application,
> and I am behind a firewall, so I was safe in keeping everything in the
> public schema.
> Dan
> --- On *Thu, 1/27/11, Henrik Berggren /<henke.berggren at gmail.com>/* wrote:
> From: Henrik Berggren <henke.berggren at gmail.com>
> Subject: Re: [pgrouting-users] Table location
> To: "pgRouting users mailing list" <pgrouting-users at lists.osgeo.org>
> Received: Thursday, January 27, 2011, 10:26 AM
> Are you sure about that the data needs to be in the public schema
> for shooting_star to work properly?
> /Henrik
> On 01/27/2011 07:06 PM, Dan Putler wrote:
>> I also found that I could only use pgrouting with a data table
>> that are in the public schema. My memory is that in some of the
>> functions (I know this is true for the shooting star algorithm),
>> the public schema is "hard wired" within the code.
>> Dan
>> --- On *Thu, 1/27/11, Daniel Kastl /<daniel at georepublic.de>
>> </mc/compose?to=daniel at georepublic.de>/* wrote:
>> From: Daniel Kastl <daniel at georepublic.de>
>> </mc/compose?to=pgrouting-users at lists.osgeo.org>
>> Received: Thursday, January 27, 2011, 8:18 AM
>> Good question, Ricardo!
>> And thank you for sharing your experience, Henrik.
>> I must admit I haven't tried it, and probably the majority of
>> users always works in public schema.
>> I added a ticket not to forget about this, because I think it
>> would be nice to support the schema in all functions:
>> https://github.com/pgRouting/pgrouting/issues/issue/24
>> Daniel
>> 2011/1/28 Henrik Berggren <henke.berggren at gmail.com>
>> You can have it in other schemes but you need to run the
>> assign_vertex_id in the public scheme, that is my experience.
>> /H
>> On 01/25/2011 10:42 PM, Ricardo Bayley wrote:
>>> Hi everyone,
>>> I am wondering, does pgrouting require to have tables on
>>> the public schema ? or could they be on any schema ?
>>> Thanks,
>>> Ricardo
>>> Pgrouting-users mailing list
>>> Pgrouting-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de
>> Web: http://georepublic.de <http://georepublic.de/>
>> -----Inline Attachment Follows-----
>> Pgrouting-users at lists.osgeo.org </mc/compose?to=Pgrouting-users at lists.osgeo.org>
More information about the Pgrouting-users
