[pgrouting-users] Table location
Dan Putler putler at yahoo.com
Sat Jan 29 12:36:36 EST 2011
Hi Steve,
Have you submitted a patch with the changes? It seems like a good change.
Dan
--- On Fri, 1/28/11, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> From: Stephen Woodbridge <woodbri at swoodbridge.com>
> Subject: Re: [pgrouting-users] Table location
> To: pgrouting-users at lists.osgeo.org
> Received: Friday, January 28, 2011, 10:00 AM
> I cloned vertex assignment code to
> change it for zlevels and it was
> trivial to make it run in another schema. I think all you
> need to do is:
> 1. remove all the explicit references to "public." from the
> stored
> procedure and reload it in you "data." schema
> 2. then make sure you set the default db search path like:
> alter database mydb set search_path to data, public;
> And everything is good.
> -Steve
> On 1/28/2011 1:39 AM, Dan Putler wrote:
> > Given your comment on vertex assignments needing to be
> done in the
> > public schema, I'm now not sure. I may have had a
> problem with the
> > vertex assignments, looked through that code and
> discovered that it
> > didn't handle anything other than the public schema
> well, and just put
> > everything in public after that. I did this in July,
> so things are on
> > the hazy side. What I was working on isn't part of a
> web application,
> > and I am behind a firewall, so I was safe in keeping
> everything in the
> > public schema.
> > Dan
> > --- On *Thu, 1/27/11, Henrik Berggren /<henke.berggren at gmail.com>/*
> wrote:
> >     From: Henrik Berggren <henke.berggren at gmail.com>
> Table location
> >     To: "pgRouting users mailing
> list" <pgrouting-users at lists.osgeo.org>
> >     Received: Thursday, January
> 27, 2011, 10:26 AM
> >     Are you sure about that the
> data needs to be in the public schema
> >     for shooting_star to work
> properly?
> >     /Henrik
> >     On 01/27/2011 07:06 PM, Dan
> Putler wrote:
> >>     I also found that I could
> only use pgrouting with a data table
> >>     that are in the public
> schema. My memory is that in some of the
> >>     functions (I know this is
> true for the shooting star algorithm),
> >>     the public schema is "hard
> wired" within the code.
> >>     Dan
> Daniel Kastl /<daniel at georepublic.de>
> >>     </mc/compose?to=daniel at georepublic.de>/*
> wrote:
> >>         From: Daniel
> Kastl <daniel at georepublic.de>
> >>         Subject: Re:
> >>         To:
> "pgRouting users mailing list"
>    </mc/compose?to=pgrouting-users at lists.osgeo.org>
> >>         Received:
> Thursday, January 27, 2011, 8:18 AM
> >>         Good
> question, Ricardo!
> >>         And thank
> you for sharing your experience, Henrik.
> >>         I must admit
> I haven't tried it, and probably the majority of
> >>         users always
> works in public schema.
> >>         I added a
> ticket not to forget about this, because I think it
> >>         would be
> nice to support the schema in all functions:
> >>         https://github.com/pgRouting/pgrouting/issues/issue/24
> >>         Daniel
> >>         2011/1/28
>    You can have it in other schemes but you
> need to run the
>    assign_vertex_id in the public scheme,
> that is my experience.
>    /H
>    On 01/25/2011 10:42 PM, Ricardo Bayley
> wrote:
>    Hi everyone,
>    I am wondering, does pgrouting require to
> have tables on
>    the public schema ? or could they be on
> any schema ?
>    Thanks,
>    Ricardo
>    _______________________________________________
>    Pgrouting-users mailing list
>    Pgrouting-users at lists.osgeo.org
>    http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> >>         Georepublic
> UG & Georepublic Japan
> >>         eMail: daniel.kastl at georepublic.de
> >>         Web: http://georepublic.de <http://georepublic.de/>
> >>         -----Inline
> Attachment Follows-----
> list
> </mc/compose?to=Pgrouting-users at lists.osgeo.org>
> >     -----Inline Attachment
> Follows-----
More information about the Pgrouting-users mailing list
