[pgrouting-users] driving_distance function nodes returned ok
edges incomplete
Daniel Kastl
daniel at georepublic.de
Wed Mar 23 05:20:25 EDT 2011
Driving distance only returns valid nodes.
The edge column is there to make the output look the same as the other
functions ... we can discuss this is a good idea or not.
Sorry for the confusion. Maybe this should be written somewhere more
clearly.
Daniel
2011/3/23 Sandor Csaba <sandor.csaba at viamap.hu>
> Hi List,
> I'm trying to figure out how the driving_distance function works.
> Here's my sql:
> SELECT * FROM driving_distance('SELECT id::int4,f_junc::int4 AS
> source,t_junc::int4 AS
> target,ST_Length(ST_Transform(the_geom,23700))::float8 AS cost FROM
> omsz_network',3094421,22500,false,false);
> The nodes in the given distance are returned correctly, but in case of
> edges some of them are returned, some other not.
> See attached image:
> Red dot is the starting point,
> black dots are nodes returned by the function.
> Red lines are the edges returned.
> Blue lines are all the street network.
> What am I doing wrong that not all the edges are returned in the
> driving distance?
> Thank you,
> Csaba
> Sándor Csaba
> szolgáltatási vezető
> ViaMap Kft.
> Székhely/postacím: 1132 Budapest, Váci út 60-62.
> Iroda:
> 1076 Budapest, Garay u. 29-31. I. 1.
> (EMLA Környezeti Management és Jog Egyesület)
> Tel: +3630/9605853
> Fax: +3617002542
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110323/f08314e7/attachment.html
More information about the Pgrouting-users
