[pgrouting-users] driving_distance function nodes returned ok
edges incomplete
Sandor Csaba
sandor.csaba at viamap.hu
Wed Mar 23 05:27:33 EDT 2011
Thank you!
That clears this for me.
I can still join the network table back to the resulting node list and
figure out all edges that are concerned.
Csaba
2011/3/23 Daniel Kastl <daniel at georepublic.de>:
> Driving distance only returns valid nodes.
> The edge column is there to make the output look the same as the other
> functions ... we can discuss this is a good idea or not.
> Sorry for the confusion. Maybe this should be written somewhere more
> clearly.
> Daniel
> 2011/3/23 Sandor Csaba <sandor.csaba at viamap.hu>
>> Hi List,
>> I'm trying to figure out how the driving_distance function works.
>> Here's my sql:
>> SELECT * FROM driving_distance('SELECT id::int4,f_junc::int4 AS
>> source,t_junc::int4 AS
>> target,ST_Length(ST_Transform(the_geom,23700))::float8 AS cost FROM
>> omsz_network',3094421,22500,false,false);
>> The nodes in the given distance are returned correctly, but in case of
>> edges some of them are returned, some other not.
>> See attached image:
>> Red dot is the starting point,
>> black dots are nodes returned by the function.
>> Red lines are the edges returned.
>> Blue lines are all the street network.
>> What am I doing wrong that not all the edges are returned in the
>> driving distance?
>> Thank you,
>> Csaba
>> Sándor Csaba
>> szolgáltatási vezető
>> ViaMap Kft.
>> Székhely/postacím: 1132 Budapest, Váci út 60-62.
>> Iroda:
>> 1076 Budapest, Garay u. 29-31. I. 1.
>> (EMLA Környezeti Management és Jog Egyesület)
>> Tel: +3630/9605853
>> Fax: +3617002542
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
Sándor Csaba
ViaMap Kft.
Iroda:
Tel: +3630/9605853
Fax: +3617002542
More information about the Pgrouting-users
