[pgrouting-users] assign_vertices_3d source code & docs
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Mar 24 20:04:16 EDT 2011
network is a postgresql type so it must be quoted. So you can try doing:
SELECT assign_vertex_id3d(’"network"’, 1, ’the_geom’, ’gid’, 'F_LEVEL',
'T_LEVEL');
This might work, but in general you might have other issues with other
stored procedures also.
You could also try changing your table name like:
alter table "network" rename to "the_network";
then reference it by the_network like:
SELECT assign_vertex_id3d(’the_network’, 1, ’the_geom’, ’gid’,
'F_LEVEL', 'T_LEVEL');
-Steve
On 3/24/2011 6:32 PM, Miroslav Novta wrote:
> Hello Dear,
> I have faced a problem with assign_vertex_id3d. It is a bit strange
> error message i have get. I have explored all code i suspect and have no
> clue. Error report is network is not a column, it is a table and it
> should be a table, i have no idea why it expect it to be a column.
> Here is error i get:
> ERROR: column "’network’" does not exist
> LINE 1: SELECT assign_vertex_id3d(’network’, 1, ’the_geom’, ’gid’, '...
> In statement:
> SELECT assign_vertex_id3d(’network’, 1, ’the_geom’, ’gid’, 'F_LEVEL',
> 'T_LEVEL');
> To explain more, network is my ways table defined with iGO standard. I
> have added source and target columns according to guide
> -- Add "source" and "target" column
> ALTER TABLE "network" ADD COLUMN "source" integer;
> ALTER TABLE "network" ADD COLUMN "target" integer;
> Do you have any idea what is wrong? What have i missed?
> Regards,
> Miroslav
> 2011/3/23 Stephen Woodbridge <woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>>
> > On 3/23/2011 10:23 AM, Miroslav Novta wrote:
> >> Steve,
> >> Thank you, I will follow your Instructions. I don't expect a lot of
> >> problems with turn restrictions because maneuvers table is still empty
> >> and will be filled after routing become functional.
> >> I still have some baby problems to make pgRouting functional.
> >> For example what is correct range of tolerance if i use meters not
> >> degrees in assign vertex?
> > This depends on your data for example in degrees if you data has a
> resolution of 0.000001 then this is a good value to use.
> > For meters, you might use 0.5 or 0.9, the best way to evaluate this
> is to look the the coordinates at the ends of to segments that should be
> connected. So:
> > abs(Xa - Xb) < tolerance
> > to match the two ends to the same node. If you set tolerance too big
> then it will merge close by nodes that should not be connected. If you
> set the tolerance too small it will not match nodes that should be
> connected. We use tolerance to deal with floating point numbers not
> being exact like integers and can have rounding errors in the numbers.
> > -Steve
> >> Miroslav
> >> <mailto:woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>>>
> >> Charles,
> >> Thank you for posting that. I am glad I read the whole thread
> >> because I was just about to did up my old code and dust it off to
> >> post. There is no need for that as your implementation accurately
> >> reflects mine.
> >> Miroslav,
> >> Regarding turn restrictions, you should search the archives for this
> >> as I have been fairly vocal about the limitations. To summarize:
> >> 1. turn restrictions only work with shooting star
> >> 2. If you have multiple turn restrictions, I think you have to enter
> >> the related links multiple times, ie: once for each restriction
> >> 3. IMHO, we need to rework the turn restrictions to make adding them
> >> more intuitive and easier
> >> 4. before you try to implement a large number of them, I would
> >> verify that you can in fact add multiple turn restrictions in a
> >> trivial graph that is easy to verify if it works as expected,
> >> because it is my sense that this area has not been used to any great
> >> extent.
> >> -Steve
> >> On 3/23/2011 7:43 AM, Charles Galpin wrote:
> >> Hi Miroslav
> >> This is an implementation I have been using which I made after a
> >> discussion with Stephen on this subject. It is essentially an
> >> implementation of his ideas and works fine for me, but ymmv.
> >> Otherwise search the email archives as I believe he posted
> his here
> >> at some point as well.
> >> hth charles
> >> On Mar 23, 2011, at 6:44 AM, Miroslav Novta wrote:
> >> Hello list,
> >> I want to use the assign_vertices_3d() function developed by
> >> Stephen Woodbridge. I want to use it for iGO shp map
> format with
> >> "turn restrictions" too.
> >> Is there source code and documentation available on any
> public
> >> repository I may access?
> >> -- Function: assign_vertex_id3d(character varying, double
> precision,
> >> character varying, character varying, character varying,
> character
> >> varying)
> >> -- DROP FUNCTION assign_vertex_id3d(character varying, double
> >> precision, character varying, character varying, character
> varying,
> >> character varying);
> >> CREATE OR REPLACE FUNCTION assign_vertex_id3d(geom_table
> character
> >> varying, tolerance double precision, geo_cname character varying,
> >> gid_cname character varying, source_zlevel_cname character
> varying,
> >> target_zlevel_cname character varying) RETURNS character
> varying AS
> >> $BODY$ DECLARE _r record; source_id int; target_id int; srid
> >> integer; BEGIN
> >> BEGIN DROP TABLE vertices_tmp; EXCEPTION WHEN UNDEFINED_TABLE
> THEN
> >> END;
> >> EXECUTE 'CREATE TABLE vertices_tmp (id serial)';
> >> -- FOR _r IN EXECUTE 'SELECT srid FROM geometry_columns WHERE
> >> f_table_name='''|| quote_ident(geom_table)||''';' LOOP --
> srid
> >> := _r.srid; -- END LOOP;
> >> srid :=
> Find_SRID('public',quote_ident(geom_table),quote_ident(geo_cname));
> >> EXECUTE 'SELECT addGeometryColumn(''vertices_tmp'', ''the_geom'',
> >> '||srid||', ''POINT'', 3)'; CREATE INDEX vertices_tmp_idx ON
> >> vertices_tmp USING GIST (the_geom);
> >> FOR _r IN EXECUTE 'SELECT ' || quote_ident(gid_cname) || ' AS
> >> id,' ||
> >> ' ST_MakePoint(ST_X(StartPoint('|| quote_ident(geo_cname) ||')),
> >> ST_Y(StartPoint('|| quote_ident(geo_cname) ||')), '||
> >> quote_ident(source_zlevel_cname) ||') AS source,' || '
> >> ST_MakePoint(ST_X(EndPoint('|| quote_ident(geo_cname) ||')),
> >> ST_Y(EndPoint('|| quote_ident(geo_cname) ||')), '||
> >> quote_ident(target_zlevel_cname) ||') AS target' || ' FROM ' ||
> >> quote_ident(geom_table) LOOP
> >> source_id := point_to_id3d(setsrid(_r.source, srid), tolerance);
> >> target_id := point_to_id3d(setsrid(_r.target, srid), tolerance);
> >> EXECUTE 'update ' || quote_ident(geom_table) || ' SET source
> >> source_id || ', target = ' || target_id || ' WHERE ' ||
> >> quote_ident(gid_cname) || ' = ' || _r.id <http://r.id>
> <http://r.id>; END LOOP;
> >> RETURN 'OK';
> >> END; $BODY$ LANGUAGE 'plpgsql' VOLATILE STRICT COST 100; ALTER
> >> FUNCTION assign_vertex_id3d(character varying, double precision,
> character
> >> varying) OWNER TO postgres;
> >> -- Function: point_to_id3d(geometry, double precision)
> >> -- DROP FUNCTION point_to_id3d(geometry, double precision);
> >> CREATE OR REPLACE FUNCTION point_to_id3d(p geometry, tolerance
> >> double
> >> precision) RETURNS bigint AS $BODY$
> >> DECLARE _r record; _id bigint; _srid integer;
> >> BEGIN
> >> _srid := Find_SRID('public','vertices_tmp','the_geom');
> >> SELECT ST_Length3D(ST_MakeLine(the_geom,p)) AS d, id
> >> INTO _r FROM vertices_tmp WHERE
> >> the_geom&& Expand(p, tolerance) AND
> >> ST_Length3D(ST_MakeLine(the_geom,p))< tolerance
> >> ORDER BY d LIMIT 1;
> >> IF FOUND THEN
> >> _id:= _r.id <http://r.id> <http://r.id>;
> >> ELSE
> >> INSERT INTO vertices_tmp(the_geom) VALUES (SetSRID(p,_srid));
> >> _id:=lastval();
> >> END IF;
> >> RETURN _id;
> >> FUNCTION point_to_id3d(geometry, double precision) OWNER TO
> >> postgres;
> >> _______________________________________________ Pgrouting-users
> >> mailing list Pgrouting-users at lists.osgeo.org
> <mailto:Pgrouting-users at lists.osgeo.org>
> <mailto:Pgrouting-users at lists.osgeo.org>>
> >> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> >> Pgrouting-users mailing list
> >> Miroslav Novta
> Miroslav Novta
More information about the Pgrouting-users
