[pgrouting-users] assign_vertices_3d source code & docs
Miroslav Novta miroslav.novta at gmail.com
Mon Mar 28 18:04:08 EDT 2011
Hi Steve,
It has changed table name to the_network and after that to ways. Error is
same all the time. Is there something wrong in function? Or i am missing
something?
*SQL error:*
ERROR:  column "’the_network’" does not exist
LINE 1: SELECT assign_vertex_id3d(’the_network’, 1, ’the_geom’, ’gid...
*In statement:*
SELECT assign_vertex_id3d(’the_network’, 1, ’the_geom’, ’gid’, 'F_LEVEL',
'T_LEVEL');
Function assign_vertex_id3d is bellow
 assign_vertex_id3d "geom_table" character varying, "tolerance" double
precision, "geo_cname" character varying, "gid_cname" character varying,
"source_zlevel_cname" character varying, "target_zlevel_cname" character
varying character varying plpgsql Definition
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
DECLARE
   _r record;
   source_id int;
   target_id int;
   srid integer;
BEGIN
   BEGIN
   DROP TABLE vertices_tmp;
   EXCEPTION
   WHEN UNDEFINED_TABLE THEN
   END;
   EXECUTE 'CREATE TABLE vertices_tmp (id serial)';
--    FOR _r IN EXECUTE 'SELECT srid FROM geometry_columns WHERE
f_table_name='''|| quote_ident(geom_table)||''';' LOOP
--      srid := _r.srid;
--    END LOOP;
   srid := Find_SRID('public',quote_ident(geom_table),quote_ident(geo_cname));
   EXECUTE 'SELECT addGeometryColumn(''vertices_tmp'', ''the_geom'',
'||srid||', ''POINT'', 3)';
   CREATE INDEX vertices_tmp_idx ON vertices_tmp USING GIST (the_geom);
   FOR _r IN EXECUTE 'SELECT ' || quote_ident(gid_cname) || ' AS id,'
           || ' ST_MakePoint(ST_X(StartPoint('||
quote_ident(geo_cname) ||')), ST_Y(StartPoint('||
quote_ident(geo_cname) ||')), '|| quote_ident(source_zlevel_cname)
||') AS source,'
           || ' ST_MakePoint(ST_X(EndPoint('|| quote_ident(geo_cname)
||')), ST_Y(EndPoint('|| quote_ident(geo_cname) ||')), '||
quote_ident(target_zlevel_cname) ||') AS target'
           || ' FROM ' || quote_ident(geom_table)
   LOOP
       source_id := point_to_id3d(setsrid(_r.source, srid), tolerance);
       target_id := point_to_id3d(setsrid(_r.target, srid), tolerance);
       EXECUTE 'update ' || quote_ident(geom_table) ||
               ' SET source = ' || source_id ||
               ', target = ' || target_id ||
               ' WHERE ' || quote_ident(gid_cname) || ' =  ' || _r.id;
   END LOOP;
   RETURN 'OK';
END;
- Miroslav
2011/3/25 Stephen Woodbridge <woodbri at swoodbridge.com>
> network is a postgresql type so it must be quoted. So you can try doing:
> SELECT assign_vertex_id3d(’"network"’, 1, ’the_geom’, ’gid’, 'F_LEVEL',
> 'T_LEVEL');
> This might work, but in general you might have other issues with other
> stored procedures also.
> You could also try changing your table name like:
> alter table "network" rename to "the_network";
> then reference it by the_network like:
> 'T_LEVEL');
> -Steve
> On 3/24/2011 6:32 PM, Miroslav Novta wrote:
>> Hello Dear,
>> I have faced a problem with assign_vertex_id3d. It is a bit strange
>> error message i have get. I have explored all code i suspect and have no
>> clue. Error report is network is not a column, it is a table and it
>> should be a table, i have no idea why it expect it to be a column.
>> Here is error i get:
>> ERROR:  column "’network’" does not exist
>> LINE 1: SELECT assign_vertex_id3d(’network’, 1, ’the_geom’, ’gid’, '...
>> In statement:
>> SELECT assign_vertex_id3d(’network’, 1, ’the_geom’, ’gid’, 'F_LEVEL',
>> 'T_LEVEL');
>> To explain more, network is my ways table defined with iGO standard. I
>> have added source and target columns according to guide
>> -- Add "source" and "target" column
>> ALTER TABLE "network" ADD COLUMN "source" integer;
>> ALTER TABLE "network" ADD COLUMN "target" integer;
>> Do you have any idea what is wrong? What have i missed?
>> Regards,
>> Miroslav
>> 2011/3/23 Stephen Woodbridge <woodbri at swoodbridge.com
>> <mailto:woodbri at swoodbridge.com>>
>>  > On 3/23/2011 10:23 AM, Miroslav Novta wrote:
>>  >> Steve,
>>  >> Thank you, I will follow your Instructions. I don't expect a lot of
>>  >> problems with turn restrictions because maneuvers table is still empty
>>  >> and will be filled after routing become functional.
>>  >> I still have some baby problems to make pgRouting functional.
>>  >> For example what is correct range of tolerance if i use meters not
>>  >> degrees in assign vertex?
>>  > This depends on your data for example in degrees if you data has a
>> resolution of 0.000001 then this is a good value to use.
>>  > For meters, you might use 0.5 or 0.9, the best way to evaluate this
>> is to look the the coordinates at the ends of to segments that should be
>> connected. So:
>>  >    abs(Xa - Xb) < tolerance
>>  > to match the two ends to the same node. If you set tolerance too big
>> then it will merge close by nodes that should not be connected. If you
>> set the tolerance too small it will not match nodes that should be
>> connected. We use tolerance to deal with floating point numbers not
>> being exact like integers and can have rounding errors in the numbers.
>>  > -Steve
>>  >> Miroslav
>>  >> <mailto:woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>>>
>>  >>    Charles,
>>  >>    Thank you for posting that. I am glad I read the whole thread
>>  >>    because I was just about to did up my old code and dust it off to
>>  >>    post.  There is no need for that as your implementation accurately
>>  >>    reflects mine.
>>  >>    Miroslav,
>>  >>    Regarding turn restrictions, you should search the archives for
>> this
>>  >>    as I have been fairly vocal about the limitations. To summarize:
>>  >>    1. turn restrictions only work with shooting star
>>  >>    2. If you have multiple turn restrictions, I think you have to
>> enter
>>  >>    the related links multiple times, ie: once for each restriction
>>  >>    3. IMHO, we need to rework the turn restrictions to make adding
>> them
>>  >>    more intuitive and easier
>>  >>    4. before you try to implement a large number of them, I would
>>  >>    verify that you can in fact add multiple turn restrictions in a
>>  >>    trivial graph that is easy to verify if it works as expected,
>>  >>    because it is my sense that this area has not been used to any
>> great
>>  >>    extent.
>>  >>    -Steve
>>  >>    On 3/23/2011 7:43 AM, Charles Galpin wrote:
>>  >>        Hi Miroslav
>>  >>        This is an implementation I have been using which I made after
>> a
>>  >>        discussion with Stephen on this subject. It is essentially an
>>  >>        implementation of his ideas and works fine for me, but ymmv.
>>  >>        Otherwise search the email archives as I believe he posted
>> his here
>>  >>        at some point as well.
>>  >>        hth charles
>>  >>        On Mar 23, 2011, at 6:44 AM, Miroslav Novta wrote:
>>  >>            Hello list,
>>  >>            I want to use the assign_vertices_3d() function developed
>> by
>>  >>            Stephen Woodbridge. I want to use it for iGO shp map
>> format with
>>  >> "turn restrictions" too.
>>  >>            Is there source code and documentation available on any
>> public
>>  >>            repository I may access?
>>  >>        -- Function: assign_vertex_id3d(character varying, double
>> precision,
>>  >>        character varying, character varying, character varying,
>> character
>>  >>        varying)
>>  >>        -- DROP FUNCTION assign_vertex_id3d(character varying, double
>>  >>        precision, character varying, character varying, character
>> varying,
>>  >>        character varying);
>>  >>        CREATE OR REPLACE FUNCTION assign_vertex_id3d(geom_table
>> character
>>  >>        varying, tolerance double precision, geo_cname character
>> varying,
>>  >>        gid_cname character varying, source_zlevel_cname character
>> varying,
>>  >>        target_zlevel_cname character varying) RETURNS character
>> varying AS
>>  >>        $BODY$ DECLARE _r record; source_id int; target_id int; srid
>>  >>        integer; BEGIN
>>  >>        BEGIN DROP TABLE vertices_tmp; EXCEPTION WHEN UNDEFINED_TABLE
>> THEN
>>  >>        END;
>> WHERE
>>  >>        f_table_name='''|| quote_ident(geom_table)||''';' LOOP --
>>  srid
>>  >>        := _r.srid; --    END LOOP;
>>  >>        srid :=
>> ''the_geom'',
>>  >> '||srid||', ''POINT'', 3)'; CREATE INDEX vertices_tmp_idx ON
>>  >>        id,' ||
>>  >> ' ST_MakePoint(ST_X(StartPoint('|| quote_ident(geo_cname) ||')),
>>  >>        ST_Y(StartPoint('|| quote_ident(geo_cname) ||')), '||
>>  >>        quote_ident(source_zlevel_cname) ||') AS source,' || '
>>  >>        ST_MakePoint(ST_X(EndPoint('|| quote_ident(geo_cname) ||')),
>>  >>        quote_ident(target_zlevel_cname) ||') AS target' || ' FROM ' ||
>>  >>        quote_ident(geom_table) LOOP
>> tolerance);
>> tolerance);
>>  >>        EXECUTE 'update ' || quote_ident(geom_table) || ' SET source
>>  >>        source_id || ', target = ' || target_id || ' WHERE ' ||
>>  >>        quote_ident(gid_cname) || ' = ' || _r.id <http://r.id>
>> <http://r.id>; END LOOP;
>>  >>        RETURN 'OK';
>>  >>        END; $BODY$ LANGUAGE 'plpgsql' VOLATILE STRICT COST 100; ALTER
>> precision,
>> character
>>  >>        varying) OWNER TO postgres;
>>  >>        -- Function: point_to_id3d(geometry, double precision)
>>  >>        -- DROP FUNCTION point_to_id3d(geometry, double precision);
>>  >>        CREATE OR REPLACE FUNCTION point_to_id3d(p geometry, tolerance
>>  >>        double
>>  >>        precision) RETURNS bigint AS $BODY$
>>  >>        DECLARE _r record; _id bigint; _srid integer;
>>  >>        BEGIN
>>  >>        _srid := Find_SRID('public','vertices_tmp','the_geom');
>>  >>        SELECT ST_Length3D(ST_MakeLine(the_geom,p)) AS d, id
>>  >>        INTO _r FROM vertices_tmp WHERE
>>  >>        the_geom&&  Expand(p, tolerance) AND
>>  >>        ST_Length3D(ST_MakeLine(the_geom,p))<  tolerance
>>  >>        ORDER BY d LIMIT 1;
>>  >>        IF FOUND THEN
>>  >>        _id:= _r.id <http://r.id> <http://r.id>;
>>  >>        ELSE
>>  >>        INSERT INTO vertices_tmp(the_geom) VALUES (SetSRID(p,_srid));
>>  >>        _id:=lastval();
>>  >>        END IF;
>>  >>        RETURN _id;
>>  >>        FUNCTION point_to_id3d(geometry, double precision) OWNER TO
>>  >>        postgres;
>>  >>        _______________________________________________ Pgrouting-users
>>  >>        mailing list Pgrouting-users at lists.osgeo.org
>> <mailto:Pgrouting-users at lists.osgeo.org>
>> <mailto:Pgrouting-users at lists.osgeo.org>>
>>  >> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>>  >>    Pgrouting-users mailing list
>>  >> Miroslav Novta
>> Miroslav Novta
Miroslav Novta
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110329/864edae8/attachment-0001.html
More information about the Pgrouting-users mailing list
