[pgrouting-users] pgrouting installation
Daniel Kastl daniel at georepublic.de
Tue Sep 13 08:37:49 EDT 2011
Hi Ali,
I may be wrong, and if there are Windows users out there who know it better,
please correct me.
But the binaries for pgRouting were not compiled with Windows 7. They might
work, but not necessarily.
Daniel
On Tue, Sep 13, 2011 at 2:39 AM, Ali Taha <ali.taha at ritaj.ps> wrote:
> Dear Daniel,****
> I downloaded them from http://www.pgrouting.org/download.html  (windows
> binaries section pgRouting-1.03_pg-8.4.2)****
> I have windows 7 OS****
> Thanks****
> *From:* pgrouting-users-bounces at lists.osgeo.org [mailto:
> pgrouting-users-bounces at lists.osgeo.org] *On Behalf Of *Daniel Kastl
> *Sent:* Tuesday, September 13, 2011 6:34 AM
> *To:* pgRouting users mailing list
> *Subject:* Re: [pgrouting-users] pgrouting installation****
> On Mon, Sep 12, 2011 at 11:20 AM, Ali Taha <ali.taha at ritaj.ps> wrote:****
> Dear All,****
> I am trying to setup and test pgrouting, I followed the setups but it is
> still not working.  If ollowed the following steps:****
> 1-      Copay pgrouting libraries to ..\pgsql\8.4\lib****
> From where did you copy them?****
> Did you compile? Which OS?****
> Daniel****
> 2-      Execute routing_core.sql and routing_core_wrappers.sql****
> 3-      Create a newtwork:****
> a.       Added source and target fields****
> b.      Execute Execute assign_vertex_id('<table>', float tolerance,
> '<geometry column', '<gid>')****
> c.       Added indices ****
> d.      Added reverse_cost column.****
> Then I used the following query to retrieve records:****
> SELECT * FROM shortest_path(‘****
> SELECT gid as id,****
> source::integer,****
> target::integer,****
> length::double precision as cost****
> FROM ways’,****
> 24154,****
> 24157,****
> false, false)****
> the query executes without errors, but return no data. I checked the table
> and the records seems OK. ****
> is there a way to validate the database and verify the topology? How to
> make sure that the pgrouting library (dlls) are installed and working
> correctly?****
> Thanks****
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users****
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de****
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110913/61510ee8/attachment.html
More information about the Pgrouting-users mailing list
