[pgrouting-users] Possible to use pgrouting for "layered" data?
Daniel Kastl daniel at georepublic.de
Tue Sep 27 22:00:07 EDT 2011
Just found out that it is possible to store routes as URL:
http://plan.epfl.ch/?zoom=20&recenter_y=5864229.75163&recenter_x=730768.62991&layerNodes=fonds,batiments,labels,information,parkings_publics,arrets_metro&floor=0&from=BM&to=Secr%C3%A9tariat_SV&disabled=true&fromId=17056&toId=30698
On Wed, Sep 28, 2011 at 10:56 AM, Daniel Kastl <daniel at georepublic.de>wrote:
> You can try it out here: http://plan.epfl.ch/
> The "campus routing" also allows to set "disabled" flag for those, who
> can't use stairs for example.
> I think the application is a bit difficult to use if you don't know room
> numbers. You can input the building ID for example, but this obviously won't
> route you between floors.
> In general pgRouting can handle different levels when you model your
> network right.
> You need to add links between the different levels and assign costs.
> Daniel
> On Wed, Sep 28, 2011 at 9:14 AM, Mario Basa <mario.basa at gmail.com> wrote:
>> Hi,
>> The original pgRouting, pgDijkstra, was created for a Swiss university
>> campus to show the path from one classroom to another in different
>> buildings.
>> So, this is definitely possible.
>> Mario.
>> On Wed, Sep 28, 2011 at 12:36 AM, Stephen Woodbridge
>> <woodbri at swoodbridge.com> wrote:
>> > On 9/27/2011 3:50 AM, Gunnar Rangøy wrote:
>> >> Hello,
>> >> I am considering to use pgrouting for routing in layered data. By
>> >> layered data i mean data that is separated in floors, which are in some
>> >> points connected via elevators/stairs between the floors.
>> >> As far as I can see, this is not directly supported. Is it done any
>> >> assumptions/choices which makes such an difficult/impossible to
>> >> implement? How well will it work to just add connections between nodes
>> >> in same floor (+elevators)?
>> > Hello Gunnar,
>> > I can not think of any reason that we can not route this kind of data.
>> The
>> > issue will be that you need to separate the nodes one different floors
>> with
>> > a z-value and add an appropriate cost for elevators and stairs.
>> elevators
>> > need to include some queue time for the elevator to arrive and then some
>> > travel time. For stairs you might want to set different costs for going
>> up
>> > vs down.
>> > Otherwise it should be totally doable.
>> > -Steve
>> > _______________________________________________
>> > Pgrouting-users mailing list
>> > Pgrouting-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110928/5f5637f2/attachment.html
More information about the Pgrouting-users mailing list
