[pgrouting-users] New Windows 32bit/64bit binary for PostgreSQL9.1
Ricardo Bayley
ricardo.bayley at gmail.com
Sat Aug 4 07:32:10 PDT 2012
Hi Sanak
What is the Shooting Star reverse cost issue which still remain for the
pg9.1 win build ?
Regards,
Ricardo
2012/7/6 Sanak <geosanak at gmail.com>
> Hi guys,
> Thanks for response :-)
> I had added the each build environments to skydrive,
> so if someone who want to make custom build on Windows exists,
> use these one.
> http://sdrv.ms/NFCgr2
> +- Build.zip ... for 32bit work folder. (extract to "C:\")
> +- MinGW.zip ... for 32bit build environment. (extract to "C:\" and run
> "C:\MinGW\msys\1.0\msys.bat")
> +- Build64.zip ... for 64bit work folder. (extract to "C:\")
> +- ming64.zip ... for 64bit build environment. (based on PostGIS one.
> extract to "C:\" and run "C:\ming64\msys\msys.bat")
> Regards,
> 2012/7/3 Sanak <geosanak at gmail.com>
>> Hi list,
>> I had build pgRouting git version for Windows
>> PostgreSQL9.1(x86_32/x86_64).
>> https://github.com/sanak/pgrouting/downloads
>> +- pgRouting-git-sanak-mingw64_20120703_pg-9.1(x86_64).zip => 64bit
>> version
>> +- pgRouting-git-sanak-mingw32_20120703_pg-9.1(x86_32).zip => 32bit
>> version
>> * Both include David Techer's roads.sql (for postgis1.x/2.x). (See
>> http://www.davidgis.fr/documentation/pgrouting-1.02/)
>> * If you use roads_postgis2.x.sql on PostGIS 2.0, in addition to
>> "postgis.sql" and "spatial_ref_sys.sql", "legacy.sql" is necessary.
>> * Shooting Star reverse cost issue still remain. (I will check Steve
>> Horn's fixes(https://github.com/stevehorn/pgrouting/commits/) till next
>> week)
>> * This archive is not ver.1.05, because many other fixes includes after
>> 1.05 release.
>> Build instruction is here.
>> https://github.com/sanak/pgrouting/blob/mingw/BUILD.mingw
>> https://github.com/sanak/pgrouting/blob/mingw/BUILD.mingw64
>> * Thanks PostGIS team for readable documents and ming64.zip archive.
>> (http://trac.osgeo.org/postgis/wiki/DevWikiWinMingW64)
>> And I will create github "Pull Request"(sanak:mingw) to pgrouting:master
>> soon.
>> Regards,
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120804/bb43dce9/attachment.html>
More information about the Pgrouting-users
