[pgrouting-users] New Windows 32bit/64bit binary for PostgreSQL9.1
Sanak geosanak at gmail.com
Sat Aug 4 09:06:04 PDT 2012
Hi Recardo,
Shooting Star reverse cost issue is confirmable by David Techer's road
sample.
(Try http://www.davidgis.fr/documentation/pgrouting-1.02/ - 6. Shortest
Path Shooting Star : shortest_path_shooting_star() section).
I had wanted to fix this issue before my busy season(July - November), but
time was up.
If you want to use Shooting Star at hurry, I will try it again at my short
summer vacation(8/11 - 8/19).
But I want to rest this summer.
Hi Stepen,
I think that current project status is too bad,
because 1.0x is broken and 2.0 is incomplete.
So I think that following interim release (like 1.5x) is necessary.
- include TRSP module at "extra" folder. (almost same as current 'trsp'
branch)
- fix packaging issue. (Windows/Mac, Boost/CGAL)
- include GSoc member's regression test system. (like PostGIS)
I think that above code change is not hard work than 2.0,
and packager(xnix/mac/win) will be able to provide TRSP module officially.
Regards,
2012/8/4 Stephen Woodbridge <woodbri at swoodbridge.com>
> Hi Guys,
> I strongly recommend that you use the turn restrict shortest path (TRSP)
> algorithm and not Shooting star.
> TRSP is significantly faster. It handles all the cases that Shooting Star
> is supposed to handle and it handles cases that are not supported by
> shooting star.
> My mind is getting a little fuzzy at this point but if I recall the
> problems with shooting star.
> 1. v1.02 or 1.03 was the last working version and it had bugs
> 2. you can not say where on an edge you want to start like you can with
> TRSP
> 3. if the start or end edge is one-way then I think the one-wayness is
> ignored.
> 4. in the results the real cost to traverse the edge is not reported
> correctly, I think it always reports the "cost" attribute not the one it
> used in solving the graph.
> 5. it is like 2-5 times slower than TRSP, this might be because of bugs
> introduced in the later version changes
> I think it would be a better use of time and effort to just create a
> wrapper to TRSP the is identical to Shooting star so you can call shooting
> star and have it executed by TRSP. Then we only have one algorithm to
> maintain and bug fix.
> I believe TRSP is getting moved into the main release as part of the
> pgRouting 2.0 release, but I don't know when that might be.
> Thanks,
>   -Steve
> On 8/4/2012 10:32 AM, Ricardo Bayley wrote:
>> Hi Sanak
>> What is the Shooting Star reverse cost issue which still remain for the
>> pg9.1 win build ?
>> Regards,
>> Ricardo
>> 2012/7/6 Sanak <geosanak at gmail.com <mailto:geosanak at gmail.com>>
>>     Hi guys,
>>     Thanks for response :-)
>>     I had added the each build environments to skydrive,
>>     so if someone who want to make custom build on Windows exists,
>>     use these one.
>>     http://sdrv.ms/NFCgr2
>>       +- Build.zip     ... for 32bit work folder. (extract to "C:\")
>>       +- MinGW.zip ... for 32bit build environment. (extract to "C:\"
>>     and run "C:\MinGW\msys\1.0\msys.bat")
>>       +- Build64.zip ... for 64bit work folder. (extract to "C:\")
>>       +- ming64.zip ... for 64bit build environment. (based on PostGIS
>>     one. extract to "C:\" and run "C:\ming64\msys\msys.bat")
>>     Regards,
>>     2012/7/3 Sanak <geosanak at gmail.com <mailto:geosanak at gmail.com>>
>>         Hi list,
>>         I had build pgRouting git version for Windows
>>         PostgreSQL9.1(x86_32/x86_64).
>>         https://github.com/sanak/**pgrouting/downloads<https://github.com/sanak/pgrouting/downloads>
>>           +- pgRouting-git-sanak-mingw64_**20120703_pg-9.1(x86_64).zip
>>         64bit version
>>           +- pgRouting-git-sanak-mingw32_**20120703_pg-9.1(x86_32).zip
>>         32bit version
>>         * Both include David Techer's roads.sql (for postgis1.x/2.x).
>>         (See http://www.davidgis.fr/**documentation/pgrouting-1.02/<http://www.davidgis.fr/documentation/pgrouting-1.02/>
>>         * If you use roads_postgis2.x.sql on PostGIS 2.0, in addition to
>>         "postgis.sql" and "spatial_ref_sys.sql", "legacy.sql" is
>> necessary.
>>         * Shooting Star reverse cost issue still remain. (I will check
>>         Steve Horn's
>>         fixes(https://github.com/**stevehorn/pgrouting/commits/<https://github.com/stevehorn/pgrouting/commits/>)
>> till next
>>         week)
>>         * This archive is not ver.1.05, because many other fixes
>>         includes after 1.05  release.
>>         Build instruction is here.
>>         https://github.com/sanak/**pgrouting/blob/mingw/BUILD.**mingw<https://github.com/sanak/pgrouting/blob/mingw/BUILD.mingw>
>>         https://github.com/sanak/**pgrouting/blob/mingw/BUILD.**mingw64<https://github.com/sanak/pgrouting/blob/mingw/BUILD.mingw64>
>>         * Thanks PostGIS team for readable documents and ming64.zip
>> archive.
>>         (http://trac.osgeo.org/**postgis/wiki/DevWikiWinMingW64<http://trac.osgeo.org/postgis/wiki/DevWikiWinMingW64>
>>         And I will create github "Pull Request"(sanak:mingw) to
>>         pgrouting:master soon.
>>         Regards,
>>     ______________________________**_________________
>>     Pgrouting-users mailing list
>>     Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org><mailto:
>> Pgrouting-users at lists.**osgeo.org <Pgrouting-users at lists.osgeo.org>>
>>     http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120805/eb13aae9/attachment-0001.html>
More information about the Pgrouting-users mailing list
