[pgrouting-users] Problem using TRSP
Stephen Woodbridge woodbri at swoodbridge.com
Thu Aug 23 06:32:14 PDT 2012
Try renaming column "cost" and see if the fixes it.
alter table japan rename column cost to old_cost;
Let us know if this fixes the problem, because it means we have a bug.
You can rename the column back the way it was with:
alter table japan rename column old_cost to cost;
Thanks,
   -Steve
On 8/23/2012 2:06 AM, Tao Romera Martinez wrote:
> Hello Stephen,
> Thank you very much for your quick answer.
> The query you asked to me to run gives some rows with cost_car=0, but
> none of them is in the list of edges returned by
> turn_restrict_shortest_path.
> Here is the query result with the cost_car for each edge:
>     vertex_id | edge_id |    cost    |  cost_car
>        284867 |  211472 |           0        |  0.07751676
>        284794 |  211471 |           0        | 0.2359118
>        134058 |  205895 |        0.15       |  0.14653888
>        284826 |  205894 |           0        |  0.042989656
>        131290 |  205893 |           0        |  0.074959315
>        127938 |  201505 |           0        |  0.054259572
>        132923 |  201504 |           0        |  0.022826955
>        282198 |  425307 |           0        |  0.07132499
>        282197 |  795399 | 0.021921627 |  0.021921627
>        282276 |  795400 |  0.05221079  |  0.05221079
>        282035 |  425170 |        0.15       |  0.0967519
>        282034 |      -1 |           0            |  -
> I am eager to try to find the reason of this strange behaviour, so
> tell me if there is anything I can do to figure it out.
> Best regards,
> Tao
> 2012/8/20 Stephen Woodbridge <woodbri at swoodbridge.com>:
>> Please keep the queries on the list.
>> No, I have no idea, I've never seen anything like that before.
>> What does this query return?
>> select count(*) from japan where cost_car=0;
>> -Steve
>> On 8/20/2012 7:26 AM, Tao Romera Martinez wrote:
>>> Dear Stephen,
>>> I have been trying to use your function for turn restricted shortest
>>> path routing.
>>> I installed the postgresql functions, prepared a table with the turn
>>> costs, and now I am able to route through a network using turn
>>> restrictions. Well, almost.
>>> When I launch a request, the column "cost" contains 0 values except
>>> for the rows where there is a turn (the cost is the one set for
>>> turns).
>>> The request is:
>>> SELECT * FROM turn_restrict_shortest_path(
>>> 'SELECT id AS id, source::integer, target::integer, cost_car AS cost
>>> FROM japan WHERE japan.geom_way && ST_MakeEnvelope(139.675, 35.729,
>>> 139.705, 35.762)',
>>> 284867,     -- node_id of start
>>> 282034,     -- node_id of end
>>> false,  -- directed graph?
>>> false,  -- has_reverse_cost?
>>> 'SELECT to_cost::double precision, teid::integer AS target_id,
>>> feid||coalesce('',''||via,'''') AS via_path FROM turn_costs WHERE teid
>>> IN (select id FROM japan WHERE japan.geom_way &&
>>> ST_MakeEnvelope(139.675, 35.729, 139.705, 35.762)) ');
>>> The ST_MakeEnvelope is just to create a window and limit the otherwise
>>> huge amount of ways.
>>> The table "japan" looks like:
>>>    id | osm_id  | osm_name | osm_source_id | osm_target_id | clazz |
>>> flags | source | target | km | kmh | cost | reverse_cost | x1 | y1 |
>>> x2 | y2 | geom_way | cost_car
>>>     1 | 4847506 |          |      31236733 |      31236584 |    11 |
>>> 1 |  24690 |  24758 | 1.6335903 |   1 | 6.5343612 |    1.6335903 |
>>> 139.7578 | 35.6437952 | 139.7688252 | 35.6349433 | <snip> | 3.2671806
>>> And the table "turn_costs" looks like:
>>>    rid | to_cost |  teid  | feid | via
>>>      1 |    0.15 |     22 |   10 |
>>>      2 |    0.15 |     21 |   10 |
>>>      3 |    0.15 |    163 |   10 |
>>>      4 |    0.15 |     27 |   10 |
>>>      5 |    0.15 |     26 |   10 |
>>>      6 |    0.15 |     27 |   11 |
>>>      7 |    0.15 |     26 |   11 |
>>>      8 |    0.15 |    229 |   11 |
>>>      9 |    0.15 | 232698 |   11 |
>>>     10 |    0.15 |    229 |   12 |
>>> The result of the query looks like:
>>>       284867 |  211472 |           0
>>>       284794 |  211471 |           0
>>>       284826 |  205894 |           0
>>>       131290 |  205893 |           0
>>>       127938 |  201505 |           0
>>>       132923 |  201504 |           0
>>>       282198 |  425307 |           0
>>>       282034 |      -1 |           0
>>> Do you have an idea about why the "cost" values are 0?
>>> Thank you very much for your help,
>>> Tao
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
