[pgrouting-users] Problem using TRSP
Tao Romera Martinez
taoromera at gmail.com
Thu Aug 23 22:32:38 PDT 2012
Sorry, Stephen, this did not fix the problem. I still have 0 in the cost column.
2012/8/23 Stephen Woodbridge <woodbri at swoodbridge.com>:
> Try renaming column "cost" and see if the fixes it.
> alter table japan rename column cost to old_cost;
> Let us know if this fixes the problem, because it means we have a bug.
> You can rename the column back the way it was with:
> alter table japan rename column old_cost to cost;
> Thanks,
> -Steve
> On 8/23/2012 2:06 AM, Tao Romera Martinez wrote:
>> Hello Stephen,
>> Thank you very much for your quick answer.
>> The query you asked to me to run gives some rows with cost_car=0, but
>> none of them is in the list of edges returned by
>> turn_restrict_shortest_path.
>> Here is the query result with the cost_car for each edge:
>> vertex_id | edge_id | cost | cost_car
>> 284867 | 211472 | 0 | 0.07751676
>> 284794 | 211471 | 0 | 0.2359118
>> 134058 | 205895 | 0.15 | 0.14653888
>> 284826 | 205894 | 0 | 0.042989656
>> 131290 | 205893 | 0 | 0.074959315
>> 127938 | 201505 | 0 | 0.054259572
>> 132923 | 201504 | 0 | 0.022826955
>> 282198 | 425307 | 0 | 0.07132499
>> 282197 | 795399 | 0.021921627 | 0.021921627
>> 282276 | 795400 | 0.05221079 | 0.05221079
>> 282035 | 425170 | 0.15 | 0.0967519
>> 282034 | -1 | 0 | -
>> I am eager to try to find the reason of this strange behaviour, so
>> tell me if there is anything I can do to figure it out.
>> Best regards,
>> Tao
>> 2012/8/20 Stephen Woodbridge <woodbri at swoodbridge.com>:
>>> Please keep the queries on the list.
>>> No, I have no idea, I've never seen anything like that before.
>>> What does this query return?
>>> select count(*) from japan where cost_car=0;
>>> -Steve
>>> On 8/20/2012 7:26 AM, Tao Romera Martinez wrote:
>>>> Dear Stephen,
>>>> I have been trying to use your function for turn restricted shortest
>>>> path routing.
>>>> I installed the postgresql functions, prepared a table with the turn
>>>> costs, and now I am able to route through a network using turn
>>>> restrictions. Well, almost.
>>>> When I launch a request, the column "cost" contains 0 values except
>>>> for the rows where there is a turn (the cost is the one set for
>>>> turns).
>>>> The request is:
>>>> SELECT * FROM turn_restrict_shortest_path(
>>>> 'SELECT id AS id, source::integer, target::integer, cost_car AS cost
>>>> FROM japan WHERE japan.geom_way && ST_MakeEnvelope(139.675, 35.729,
>>>> 139.705, 35.762)',
>>>> 284867, -- node_id of start
>>>> 282034, -- node_id of end
>>>> false, -- directed graph?
>>>> false, -- has_reverse_cost?
>>>> 'SELECT to_cost::double precision, teid::integer AS target_id,
>>>> feid||coalesce('',''||via,'''') AS via_path FROM turn_costs WHERE teid
>>>> IN (select id FROM japan WHERE japan.geom_way &&
>>>> ST_MakeEnvelope(139.675, 35.729, 139.705, 35.762)) ');
>>>> The ST_MakeEnvelope is just to create a window and limit the otherwise
>>>> huge amount of ways.
>>>> The table "japan" looks like:
>>>> id | osm_id | osm_name | osm_source_id | osm_target_id | clazz |
>>>> flags | source | target | km | kmh | cost | reverse_cost | x1 | y1 |
>>>> x2 | y2 | geom_way | cost_car
>>>> 1 | 4847506 | | 31236733 | 31236584 | 11 |
>>>> 1 | 24690 | 24758 | 1.6335903 | 1 | 6.5343612 | 1.6335903 |
>>>> 139.7578 | 35.6437952 | 139.7688252 | 35.6349433 | <snip> | 3.2671806
>>>> And the table "turn_costs" looks like:
>>>> rid | to_cost | teid | feid | via
>>>> 1 | 0.15 | 22 | 10 |
>>>> 2 | 0.15 | 21 | 10 |
>>>> 3 | 0.15 | 163 | 10 |
>>>> 4 | 0.15 | 27 | 10 |
>>>> 5 | 0.15 | 26 | 10 |
>>>> 6 | 0.15 | 27 | 11 |
>>>> 7 | 0.15 | 26 | 11 |
>>>> 8 | 0.15 | 229 | 11 |
>>>> 9 | 0.15 | 232698 | 11 |
>>>> 10 | 0.15 | 229 | 12 |
>>>> The result of the query looks like:
>>>> 284867 | 211472 | 0
>>>> 284794 | 211471 | 0
>>>> 284826 | 205894 | 0
>>>> 131290 | 205893 | 0
>>>> 127938 | 201505 | 0
>>>> 132923 | 201504 | 0
>>>> 282198 | 425307 | 0
>>>> 282034 | -1 | 0
>>>> Do you have an idea about why the "cost" values are 0?
>>>> Thank you very much for your help,
>>>> Tao
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
