[pgrouting-users] Problem using TRSP
Tao Romera Martinez taoromera at gmail.com
Thu Aug 30 04:32:58 PDT 2012
Can you think of anything I could try to find the source of the problem?
2012/8/24 Tao Romera Martinez <taoromera at gmail.com>:
> Sorry, Stephen, this did not fix the problem. I still have 0 in the cost column.
> 2012/8/23 Stephen Woodbridge <woodbri at swoodbridge.com>:
>> Try renaming column "cost" and see if the fixes it.
>> alter table japan rename column cost to old_cost;
>> Let us know if this fixes the problem, because it means we have a bug.
>> You can rename the column back the way it was with:
>> alter table japan rename column old_cost to cost;
>> Thanks,
>>   -Steve
>> On 8/23/2012 2:06 AM, Tao Romera Martinez wrote:
>>> Hello Stephen,
>>> Thank you very much for your quick answer.
>>> The query you asked to me to run gives some rows with cost_car=0, but
>>> none of them is in the list of edges returned by
>>> turn_restrict_shortest_path.
>>> Here is the query result with the cost_car for each edge:
>>>     vertex_id | edge_id |    cost    |  cost_car
>>>        284867 |  211472 |           0        |  0.07751676
>>>        284794 |  211471 |           0        | 0.2359118
>>>        134058 |  205895 |        0.15       |  0.14653888
>>>        284826 |  205894 |           0        |  0.042989656
>>>        131290 |  205893 |           0        |  0.074959315
>>>        127938 |  201505 |           0        |  0.054259572
>>>        132923 |  201504 |           0        |  0.022826955
>>>        282198 |  425307 |           0        |  0.07132499
>>>        282197 |  795399 | 0.021921627 |  0.021921627
>>>        282276 |  795400 |  0.05221079  |  0.05221079
>>>        282035 |  425170 |        0.15       |  0.0967519
>>>        282034 |      -1 |           0            |  -
>>> I am eager to try to find the reason of this strange behaviour, so
>>> tell me if there is anything I can do to figure it out.
>>> Best regards,
>>> Tao
>>> 2012/8/20 Stephen Woodbridge <woodbri at swoodbridge.com>:
>>>> Please keep the queries on the list.
>>>> No, I have no idea, I've never seen anything like that before.
>>>> What does this query return?
>>>> select count(*) from japan where cost_car=0;
>>>> -Steve
>>>> On 8/20/2012 7:26 AM, Tao Romera Martinez wrote:
>>>>> Dear Stephen,
>>>>> I have been trying to use your function for turn restricted shortest
>>>>> path routing.
>>>>> I installed the postgresql functions, prepared a table with the turn
>>>>> costs, and now I am able to route through a network using turn
>>>>> restrictions. Well, almost.
>>>>> When I launch a request, the column "cost" contains 0 values except
>>>>> for the rows where there is a turn (the cost is the one set for
>>>>> turns).
>>>>> The request is:
>>>>> SELECT * FROM turn_restrict_shortest_path(
>>>>> 'SELECT id AS id, source::integer, target::integer, cost_car AS cost
>>>>> FROM japan WHERE japan.geom_way && ST_MakeEnvelope(139.675, 35.729,
>>>>> 139.705, 35.762)',
>>>>> 284867,     -- node_id of start
>>>>> 282034,     -- node_id of end
>>>>> false,  -- directed graph?
>>>>> false,  -- has_reverse_cost?
>>>>> 'SELECT to_cost::double precision, teid::integer AS target_id,
>>>>> feid||coalesce('',''||via,'''') AS via_path FROM turn_costs WHERE teid
>>>>> IN (select id FROM japan WHERE japan.geom_way &&
>>>>> ST_MakeEnvelope(139.675, 35.729, 139.705, 35.762)) ');
>>>>> The ST_MakeEnvelope is just to create a window and limit the otherwise
>>>>> huge amount of ways.
>>>>> The table "japan" looks like:
>>>>>    id | osm_id  | osm_name | osm_source_id | osm_target_id | clazz |
>>>>> flags | source | target | km | kmh | cost | reverse_cost | x1 | y1 |
>>>>> x2 | y2 | geom_way | cost_car
>>>>>     1 | 4847506 |          |      31236733 |      31236584 |    11 |
>>>>> 1 |  24690 |  24758 | 1.6335903 |   1 | 6.5343612 |    1.6335903 |
>>>>> 139.7578 | 35.6437952 | 139.7688252 | 35.6349433 | <snip> | 3.2671806
>>>>> And the table "turn_costs" looks like:
>>>>>    rid | to_cost |  teid  | feid | via
>>>>>      1 |    0.15 |     22 |   10 |
>>>>>      2 |    0.15 |     21 |   10 |
>>>>>      3 |    0.15 |    163 |   10 |
>>>>>      4 |    0.15 |     27 |   10 |
>>>>>      5 |    0.15 |     26 |   10 |
>>>>>      6 |    0.15 |     27 |   11 |
>>>>>      7 |    0.15 |     26 |   11 |
>>>>>      8 |    0.15 |    229 |   11 |
>>>>>      9 |    0.15 | 232698 |   11 |
>>>>>     10 |    0.15 |    229 |   12 |
>>>>> The result of the query looks like:
>>>>>       284867 |  211472 |           0
>>>>>       284794 |  211471 |           0
>>>>>       284826 |  205894 |           0
>>>>>       131290 |  205893 |           0
>>>>>       127938 |  201505 |           0
>>>>>       132923 |  201504 |           0
>>>>>       282198 |  425307 |           0
>>>>>       282034 |      -1 |           0
>>>>> Do you have an idea about why the "cost" values are 0?
>>>>> Thank you very much for your help,
>>>>> Tao
>>> Pgrouting-users mailing list
>>> Pgrouting-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
