[pgrouting-users] Problem using TRSP
Stephen Woodbridge woodbri at swoodbridge.com
Thu Aug 30 08:22:03 PDT 2012
On 8/30/2012 11:08 AM, Christy Nieman wrote:
> All,
> I'd just like to note that I have noticed this too, and it only seems to
> happen for me if I'm not using a directed graph (e.g. reverse_cost and
> the two booleans to true).
Tao, make sure you try your graph with a directed graph.
> TRSP also seems to not calculate the same routes as A-Star or Dijkstra
> if not using a directed graph.
It is possible that there are multiple paths with the same length, in
which case the result will vary depending on the algorithm sets up the
queue. If you are say that it is compute the "wrong" route as in there
is a shorter route if you are not applying restriction. then you should
probably create a simple test case and fill it with a bug so we can look
into it.
-Steve
> Christy
> On 08/30/2012 07:32 AM, Tao Romera Martinez wrote:
>> Can you think of anything I could try to find the source of the problem?
>> 2012/8/24 Tao Romera Martinez <taoromera at gmail.com>:
>>> Sorry, Stephen, this did not fix the problem. I still have 0 in the
>>> cost column.
>>> 2012/8/23 Stephen Woodbridge <woodbri at swoodbridge.com>:
>>>> Try renaming column "cost" and see if the fixes it.
>>>> alter table japan rename column cost to old_cost;
>>>> Let us know if this fixes the problem, because it means we have a bug.
>>>> You can rename the column back the way it was with:
>>>> alter table japan rename column old_cost to cost;
>>>> Thanks,
>>>>    -Steve
>>>> On 8/23/2012 2:06 AM, Tao Romera Martinez wrote:
>>>>> Hello Stephen,
>>>>> Thank you very much for your quick answer.
>>>>> The query you asked to me to run gives some rows with cost_car=0, but
>>>>> none of them is in the list of edges returned by
>>>>> turn_restrict_shortest_path.
>>>>> Here is the query result with the cost_car for each edge:
>>>>>      vertex_id | edge_id |    cost    |  cost_car
>>>>>         284867 |  211472 |           0        |  0.07751676
>>>>>         284794 |  211471 |           0        | 0.2359118
>>>>>         134058 |  205895 |        0.15       |  0.14653888
>>>>>         284826 |  205894 |           0        |  0.042989656
>>>>>         131290 |  205893 |           0        |  0.074959315
>>>>>         127938 |  201505 |           0        |  0.054259572
>>>>>         132923 |  201504 |           0        |  0.022826955
>>>>>         282198 |  425307 |           0        |  0.07132499
>>>>>         282197 |  795399 | 0.021921627 |  0.021921627
>>>>>         282276 |  795400 |  0.05221079  |  0.05221079
>>>>>         282035 |  425170 |        0.15       |  0.0967519
>>>>>         282034 |      -1 |           0            |  -
>>>>> I am eager to try to find the reason of this strange behaviour, so
>>>>> tell me if there is anything I can do to figure it out.
>>>>> Best regards,
>>>>> Tao
>>>>> 2012/8/20 Stephen Woodbridge <woodbri at swoodbridge.com>:
>>>>>> Please keep the queries on the list.
>>>>>> No, I have no idea, I've never seen anything like that before.
>>>>>> What does this query return?
>>>>>> select count(*) from japan where cost_car=0;
>>>>>> -Steve
>>>>>> On 8/20/2012 7:26 AM, Tao Romera Martinez wrote:
>>>>>>> Dear Stephen,
>>>>>>> I have been trying to use your function for turn restricted shortest
>>>>>>> path routing.
>>>>>>> I installed the postgresql functions, prepared a table with the turn
>>>>>>> costs, and now I am able to route through a network using turn
>>>>>>> restrictions. Well, almost.
>>>>>>> When I launch a request, the column "cost" contains 0 values except
>>>>>>> for the rows where there is a turn (the cost is the one set for
>>>>>>> turns).
>>>>>>> The request is:
>>>>>>> SELECT * FROM turn_restrict_shortest_path(
>>>>>>> 'SELECT id AS id, source::integer, target::integer, cost_car AS cost
>>>>>>> FROM japan WHERE japan.geom_way && ST_MakeEnvelope(139.675, 35.729,
>>>>>>> 139.705, 35.762)',
>>>>>>> 284867,     -- node_id of start
>>>>>>> 282034,     -- node_id of end
>>>>>>> false,  -- directed graph?
>>>>>>> false,  -- has_reverse_cost?
>>>>>>> 'SELECT to_cost::double precision, teid::integer AS target_id,
>>>>>>> feid||coalesce('',''||via,'''') AS via_path FROM turn_costs WHERE
>>>>>>> teid
>>>>>>> IN (select id FROM japan WHERE japan.geom_way &&
>>>>>>> ST_MakeEnvelope(139.675, 35.729, 139.705, 35.762)) ');
>>>>>>> The ST_MakeEnvelope is just to create a window and limit the
>>>>>>> otherwise
>>>>>>> huge amount of ways.
>>>>>>> The table "japan" looks like:
>>>>>>>     id | osm_id  | osm_name | osm_source_id | osm_target_id |
>>>>>>> clazz |
>>>>>>> flags | source | target | km | kmh | cost | reverse_cost | x1 | y1 |
>>>>>>> x2 | y2 | geom_way | cost_car
>>>>>>>      1 | 4847506 |          |      31236733 |      31236584 |
>>>>>>> 11 |
>>>>>>> 1 |  24690 |  24758 | 1.6335903 |   1 | 6.5343612 |    1.6335903 |
>>>>>>> 139.7578 | 35.6437952 | 139.7688252 | 35.6349433 | <snip> |
>>>>>>> 3.2671806
>>>>>>> And the table "turn_costs" looks like:
>>>>>>>     rid | to_cost |  teid  | feid | via
>>>>>>>       1 |    0.15 |     22 |   10 |
>>>>>>>       2 |    0.15 |     21 |   10 |
>>>>>>>       3 |    0.15 |    163 |   10 |
>>>>>>>       4 |    0.15 |     27 |   10 |
>>>>>>>       5 |    0.15 |     26 |   10 |
>>>>>>>       6 |    0.15 |     27 |   11 |
>>>>>>>       7 |    0.15 |     26 |   11 |
>>>>>>>       8 |    0.15 |    229 |   11 |
>>>>>>>       9 |    0.15 | 232698 |   11 |
>>>>>>>      10 |    0.15 |    229 |   12 |
>>>>>>> The result of the query looks like:
>>>>>>>        284867 |  211472 |           0
>>>>>>>        284794 |  211471 |           0
>>>>>>>        284826 |  205894 |           0
>>>>>>>        131290 |  205893 |           0
>>>>>>>        127938 |  201505 |           0
>>>>>>>        132923 |  201504 |           0
>>>>>>>        282198 |  425307 |           0
>>>>>>>        282034 |      -1 |           0
>>>>>>> Do you have an idea about why the "cost" values are 0?
>>>>>>> Thank you very much for your help,
>>>>>>> Tao
>>>>> _______________________________________________
>>>>> Pgrouting-users mailing list
>>>>> Pgrouting-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
