[pgrouting-users] Problem using TRSP
    Christy Nieman
    cnieman at dmsolutions.ca
    Thu Aug 30 08:27:27 PDT 2012
I'll see if I can come up with a simple test case that demonstrates
this.  I think it's taking the "wrong" route, but it may possibly be a
route of lower cost than the other two algorithms are using.  I'll look
into that too.
Christy
On 08/30/2012 11:22 AM, Stephen Woodbridge wrote:
> On 8/30/2012 11:08 AM, Christy Nieman wrote:
>> All,
>> I'd just like to note that I have noticed this too, and it only seems to
>> happen for me if I'm not using a directed graph (e.g. reverse_cost and
>> the two booleans to true).
> Tao, make sure you try your graph with a directed graph.
>> TRSP also seems to not calculate the same routes as A-Star or Dijkstra
>> if not using a directed graph.
> It is possible that there are multiple paths with the same length, in
> which case the result will vary depending on the algorithm sets up the
> queue. If you are say that it is compute the "wrong" route as in there
> is a shorter route if you are not applying restriction. then you
> should probably create a simple test case and fill it with a bug so we
> can look into it.
> -Steve
>> Christy
>> On 08/30/2012 07:32 AM, Tao Romera Martinez wrote:
>>> Can you think of anything I could try to find the source of the
>>> problem?
>>> 2012/8/24 Tao Romera Martinez <taoromera at gmail.com>:
>>>> Sorry, Stephen, this did not fix the problem. I still have 0 in the
>>>> cost column.
>>>> 2012/8/23 Stephen Woodbridge <woodbri at swoodbridge.com>:
>>>>> Try renaming column "cost" and see if the fixes it.
>>>>> alter table japan rename column cost to old_cost;
>>>>> Let us know if this fixes the problem, because it means we have a
>>>>> bug.
>>>>> You can rename the column back the way it was with:
>>>>> alter table japan rename column old_cost to cost;
>>>>> Thanks,
>>>>>    -Steve
>>>>> On 8/23/2012 2:06 AM, Tao Romera Martinez wrote:
>>>>>> Hello Stephen,
>>>>>> Thank you very much for your quick answer.
>>>>>> The query you asked to me to run gives some rows with cost_car=0,
>>>>>> but
>>>>>> none of them is in the list of edges returned by
>>>>>> turn_restrict_shortest_path.
>>>>>> Here is the query result with the cost_car for each edge:
>>>>>>      vertex_id | edge_id |    cost    |  cost_car
>>>>>>         284867 |  211472 |           0        | 0.07751676
>>>>>>         284794 |  211471 |           0        | 0.2359118
>>>>>>         134058 |  205895 |        0.15       | 0.14653888
>>>>>>         284826 |  205894 |           0        | 0.042989656
>>>>>>         131290 |  205893 |           0        | 0.074959315
>>>>>>         127938 |  201505 |           0        | 0.054259572
>>>>>>         132923 |  201504 |           0        | 0.022826955
>>>>>>         282198 |  425307 |           0        | 0.07132499
>>>>>>         282197 |  795399 | 0.021921627 |  0.021921627
>>>>>>         282276 |  795400 |  0.05221079  |  0.05221079
>>>>>>         282035 |  425170 |        0.15       | 0.0967519
>>>>>>         282034 |      -1 |           0            |  -
>>>>>> I am eager to try to find the reason of this strange behaviour, so
>>>>>> tell me if there is anything I can do to figure it out.
>>>>>> Best regards,
>>>>>> Tao
>>>>>> 2012/8/20 Stephen Woodbridge <woodbri at swoodbridge.com>:
>>>>>>> Please keep the queries on the list.
>>>>>>> No, I have no idea, I've never seen anything like that before.
>>>>>>> What does this query return?
>>>>>>> select count(*) from japan where cost_car=0;
>>>>>>> -Steve
>>>>>>> On 8/20/2012 7:26 AM, Tao Romera Martinez wrote:
>>>>>>>> Dear Stephen,
>>>>>>>> I have been trying to use your function for turn restricted
>>>>>>>> shortest
>>>>>>>> path routing.
>>>>>>>> I installed the postgresql functions, prepared a table with the
>>>>>>>> turn
>>>>>>>> costs, and now I am able to route through a network using turn
>>>>>>>> restrictions. Well, almost.
>>>>>>>> When I launch a request, the column "cost" contains 0 values
>>>>>>>> except
>>>>>>>> for the rows where there is a turn (the cost is the one set for
>>>>>>>> turns).
>>>>>>>> The request is:
>>>>>>>> SELECT * FROM turn_restrict_shortest_path(
>>>>>>>> 'SELECT id AS id, source::integer, target::integer, cost_car AS
>>>>>>>> cost
>>>>>>>> FROM japan WHERE japan.geom_way && ST_MakeEnvelope(139.675,
>>>>>>>> 35.729,
>>>>>>>> 139.705, 35.762)',
>>>>>>>> 284867,     -- node_id of start
>>>>>>>> 282034,     -- node_id of end
>>>>>>>> false,  -- directed graph?
>>>>>>>> false,  -- has_reverse_cost?
>>>>>>>> 'SELECT to_cost::double precision, teid::integer AS target_id,
>>>>>>>> feid||coalesce('',''||via,'''') AS via_path FROM turn_costs WHERE
>>>>>>>> teid
>>>>>>>> IN (select id FROM japan WHERE japan.geom_way &&
>>>>>>>> ST_MakeEnvelope(139.675, 35.729, 139.705, 35.762)) ');
>>>>>>>> The ST_MakeEnvelope is just to create a window and limit the
>>>>>>>> otherwise
>>>>>>>> huge amount of ways.
>>>>>>>> The table "japan" looks like:
>>>>>>>>     id | osm_id  | osm_name | osm_source_id | osm_target_id |
>>>>>>>> clazz |
>>>>>>>> flags | source | target | km | kmh | cost | reverse_cost | x1 |
>>>>>>>> y1 |
>>>>>>>> x2 | y2 | geom_way | cost_car
>>>>>>>>      1 | 4847506 |          |      31236733 | 31236584 |
>>>>>>>> 11 |
>>>>>>>> 1 |  24690 |  24758 | 1.6335903 |   1 | 6.5343612 |    1.6335903 |
>>>>>>>> 139.7578 | 35.6437952 | 139.7688252 | 35.6349433 | <snip> |
>>>>>>>> 3.2671806
>>>>>>>> And the table "turn_costs" looks like:
>>>>>>>>     rid | to_cost |  teid  | feid | via
>>>>>>>>       1 |    0.15 |     22 |   10 |
>>>>>>>>       2 |    0.15 |     21 |   10 |
>>>>>>>>       3 |    0.15 |    163 |   10 |
>>>>>>>>       4 |    0.15 |     27 |   10 |
>>>>>>>>       5 |    0.15 |     26 |   10 |
>>>>>>>>       6 |    0.15 |     27 |   11 |
>>>>>>>>       7 |    0.15 |     26 |   11 |
>>>>>>>>       8 |    0.15 |    229 |   11 |
>>>>>>>>       9 |    0.15 | 232698 |   11 |
>>>>>>>>      10 |    0.15 |    229 |   12 |
>>>>>>>> The result of the query looks like:
>>>>>>>>        284867 |  211472 |           0
>>>>>>>>        284794 |  211471 |           0
>>>>>>>>        284826 |  205894 |           0
>>>>>>>>        131290 |  205893 |           0
>>>>>>>>        127938 |  201505 |           0
>>>>>>>>        132923 |  201504 |           0
>>>>>>>>        282198 |  425307 |           0
>>>>>>>>        282034 |      -1 |           0
>>>>>>>> Do you have an idea about why the "cost" values are 0?
>>>>>>>> Thank you very much for your help,
>>>>>>>> Tao
>>>>>> _______________________________________________
>>>>>> Pgrouting-users mailing list
>>>>>> Pgrouting-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
