[pgrouting-users] core dump in server while calling driving_distance function for generating a polygon
Stephen Woodbridge woodbri at swoodbridge.com
Thu Feb 9 10:40:29 EST 2012
Dave,
This sounds like you might have multiple librouting.so look here:
/usr/lib/postgresql/8.4/lib/librouting.so
change the version to match yours.
Also try:
locate librouting.so
ldd /usr/lib/postgresql/8.4/lib/librouting.so
and make sure you do not have multiple copies of dependent libraries
loaded. Like in /usr/lib and /usr/local/lib
See if you can determine if msg_rsv is getting a null pointer passed to
it. But anything is possible if the loading is messed up.
-Steve
On 2/9/2012 12:57 AM, Dave Potts wrote:
> While calling the driving_dstance function from routing_dd_wrappers.sql,
> line  78
> My postgres server back DIES
> I tried rebuilding from source and attaching and instance of gdb to the
> server process as pg_backend_pid();
> By doing something like gdb /usr/lib/postgresql/9.1/bin/postgres pid
> Gdb claims that server process dies in msg_rsv
> I think I am using the wrong image because none of the DD code is being used.
> By turning on debug statments,  I managed to strace the problem to the
> c/c++ interface between alpha_shape
> I get lots of prints until the routine
>   ret = alpha_shape(vertices, total_tuples, res, res_count,&err_msg);
> is called.
> I tried puting in calls like
> write(2,"Hello\n",6); and  elog(ERROR, "Hello world" ,"eeee"); as the
> first line in alpha_shape, nothing evers gets printed
> So I suspect it might be a linking issue!
> Is this a known problem?
> What process image should I be attaching gbc to?
> regards
> Dave
More information about the Pgrouting-users mailing list
