[pgrouting-users] core dump in server while calling
driving_distance function for generating a polygon
Dave Potts
dave.potts at pinan.co.uk
Thu Feb 9 00:57:54 EST 2012
While calling the driving_dstance function from routing_dd_wrappers.sql,
line 78
My postgres server back DIES
I tried rebuilding from source and attaching and instance of gdb to the
server process as pg_backend_pid();
By doing something like gdb /usr/lib/postgresql/9.1/bin/postgres pid
Gdb claims that server process dies in msg_rsv
I think I am using the wrong image because none of the DD code is being used.
By turning on debug statments, I managed to strace the problem to the
c/c++ interface between alpha_shape
I get lots of prints until the routine
ret = alpha_shape(vertices, total_tuples, res, res_count, &err_msg);
is called.
I tried puting in calls like
write(2,"Hello\n",6); and elog(ERROR, "Hello world" ,"eeee"); as the
first line in alpha_shape, nothing evers gets printed
So I suspect it might be a linking issue!
Is this a known problem?
What process image should I be attaching gbc to?
regards
Dave
More information about the Pgrouting-users
