FIXED] Re: [pgrouting-users] core dump in server while calling driving_distance function for generating a polygon
Stephen Woodbridge woodbri at swoodbridge.com
Sun Feb 12 09:02:36 EST 2012
Hi Dave,
Thank you for digging into this issue and finding a fix. The fix sounds
reasonable. Can you open a ticket on this and attach a patch or a git
pull request if you have the changes in github.
Thank you for your effort on this.
-Steve
On 2/12/2012 7:17 AM, Dave Potts wrote:
> Hello list
> Thanks to those that tried to help me
> Problem found
> I am calling the function driving_distance from the file
> routing_dd_wrappers.sql at line 78.
> This is my input data
> 0 X 3000.000000   Y 3000.000000
> 1 X 3000.000000   Y 3000.000000
> 2 X 3000.000000   Y 3000.000000
> 3 X 3000.000000   Y 3000.000000
> 4 X 4000.000000   Y 2000.000000
> 5 X 4000.000000   Y 2000.000000
> If you look at it careful, you will notice less than 3 different values
> which is the source of the problem.  The Alpha_shape_2 routine blow up
> with a core dump unless you have 3 or more different alpha values in it.
> This little problem is not described in the CGAL support.
> Attempts are made to catch it in the route source, but these fail because
> it overlooks the problem of the same data appearing twice.
> ie do
> Will pass the current checks.
> I think we need to add the following code at line 166 of alpha_drivedist.cpp
> Alpha_shape_2 A(points.begin(), points.end(),
>                    coord_type(10000),
>                    Alpha_shape_2::GENERAL);
>    // check that there are more than 3 values in A otherwise you get a core
>    // dump
>    if( A.number_of_alphas()<  3){
>          *err_msg=(char*)"Driving distance requires at least 3 different
> distinct values";
>          return -1;
>    std::vector<Segment>  segments;
>    std::vector<Segment>  result;
> ie get the alpha_shape_2 code to check the number of distinct values, if
> its less than 3 issue a message but do not core dump and take the database
> down.
> Dave.
> Dave Potts wrote:
>> Now problems with the LD_LIBRARY_PATH, but just in case of errors i
>> removed the extra copies of libroute.so, nochanges.
>> As I said the problem seems to be alpha_shape routine.
>> Dave.
>> Stephen Woodbridge wrote:
>>> Dave,
>>> This sounds like you might have multiple librouting.so look here:
>>> /usr/lib/postgresql/8.4/lib/librouting.so
>>> change the version to match yours.
>>> Also try:
>>> locate librouting.so
>>> ldd /usr/lib/postgresql/8.4/lib/librouting.so
>>> and make sure you do not have multiple copies of dependent libraries
>>> loaded. Like in /usr/lib and /usr/local/lib
>>> See if you can determine if msg_rsv is getting a null pointer passed to
>>> it. But anything is possible if the loading is messed up.
>>> -Steve
>>> On 2/9/2012 12:57 AM, Dave Potts wrote:
>>>> While calling the driving_dstance function from
>>>> routing_dd_wrappers.sql,
>>>> line  78
>>>> My postgres server back DIES
>>>> I tried rebuilding from source and attaching and instance of gdb to the
>>>> server process as pg_backend_pid();
>>>> By doing something like gdb /usr/lib/postgresql/9.1/bin/postgres pid
>>>> Gdb claims that server process dies in msg_rsv
>>>> I think I am using the wrong image because none of the DD code is being
>>>> used.
>>>> By turning on debug statments,  I managed to strace the problem to the
>>>> c/c++ interface between alpha_shape
>>>> I get lots of prints until the routine
>>>>    ret = alpha_shape(vertices, total_tuples, res, res_count,&err_msg);
>>>> is called.
>>>> I tried puting in calls like
>>>> write(2,"Hello\n",6); and  elog(ERROR, "Hello world" ,"eeee"); as the
>>>> first line in alpha_shape, nothing evers gets printed
>>>> So I suspect it might be a linking issue!
>>>> Is this a known problem?
>>>> What process image should I be attaching gbc to?
>>>> regards
>>>> Dave
>>> Pgrouting-users mailing list
>>> Pgrouting-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
