FIXED] Re: [pgrouting-users] core dump in server while calling
driving_distance function for generating a polygon
Daniel Kastl
daniel at georepublic.de
Mon Feb 13 08:41:03 EST 2012
Hi Dave,
GitHub is where the pgRouting source code is hosted:
https://github.com/pgrouting/pgrouting
It makes collaboration and code contribution relatively easy (at least
compared to what pgRouting used before).
You can read more in details how it works at http://help.github.com/
In short you create an account, fork the pgRouting repository (it's just as
simple as cklick the "Fork" button), then either make changes to your
personal fork on your own PC or even directly on the Github website (you
can edit source files there in your own fork).
When you're done you can submit a "Pull request" (a button click again) and
we can review the changes, test and merge them to the main repository. And
also the credits go to you :-)
Daniel
On Mon, Feb 13, 2012 at 8:01 PM, Dave Potts <dave.potts at pinan.co.uk> wrote:
> Hi Steve
> A small problem, what the heck is a github?
> I assume it some sort of source control system, whats its address and is
> there any documentation on it?
> Dave
> Stephen Woodbridge wrote:
> > Hi Dave,
> > Thank you for digging into this issue and finding a fix. The fix sounds
> > reasonable. Can you open a ticket on this and attach a patch or a git
> > pull request if you have the changes in github.
> > Thank you for your effort on this.
> > -Steve
> > On 2/12/2012 7:17 AM, Dave Potts wrote:
> >> Hello list
> >> Thanks to those that tried to help me
> >> Problem found
> >> I am calling the function driving_distance from the file
> >> routing_dd_wrappers.sql at line 78.
> >> This is my input data
> >> 0 X 3000.000000 Y 3000.000000
> >> 1 X 3000.000000 Y 3000.000000
> >> 2 X 3000.000000 Y 3000.000000
> >> 3 X 3000.000000 Y 3000.000000
> >> 4 X 4000.000000 Y 2000.000000
> >> 5 X 4000.000000 Y 2000.000000
> >> If you look at it careful, you will notice less than 3 different values
> >> which is the source of the problem. The Alpha_shape_2 routine blow up
> >> with a core dump unless you have 3 or more different alpha values in it.
> >> This little problem is not described in the CGAL support.
> >> Attempts are made to catch it in the route source, but these fail
> >> because
> >> it overlooks the problem of the same data appearing twice.
> >> ie do
> >> Will pass the current checks.
> >> I think we need to add the following code at line 166 of
> >> alpha_drivedist.cpp
> >> Alpha_shape_2 A(points.begin(), points.end(),
> >> coord_type(10000),
> >> Alpha_shape_2::GENERAL);
> >> // check that there are more than 3 values in A otherwise you get a
> >> core
> >> // dump
> >> if( A.number_of_alphas()< 3){
> >> *err_msg=(char*)"Driving distance requires at least 3
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120213/7e498641/attachment.html
More information about the Pgrouting-users
