[pgrouting-users] ERROR: Error computing path: | SQL state: 38001
Palatla Srikanth
spalatla at gmail.com
Wed Feb 22 03:40:48 EST 2012
We are developing an web application that users PostgreSQL 8.4 +
PostGIS1.5 + Pgrouting 1.03 + development using (Java + Struts + Hibernate)
*When this Query is executed:*
SELECT ST_AsText(the_geom),id AS Coords FROM delhi_road WHERE id IN (SELECT
edge_id FROM shortest_path_astar('SELECT id, source,
target,x1,y1,x2,y2,cost,reverse_cost from delhi_road',550,662,true,true))
We are getting the below mentioned error and the other users accessing the
application were too facing the database exceptions. Can someone help us to
fix this issue.
*Error from the postgreSQL query*
********** Error **********
SQL state: 38001
*Query used:*
*Error on the Application server (IDE)*
[ INFO] 46:48 (*MapServiceDAO.java:generateRoute:1525*)
Query is......SELECT ST_AsText(the_geom),id AS Coords FROM delhi_road WHERE
id IN (SELECT edge_id FROM shortest_path_astar('SELECT id, source,
[ INFO] 46:48 (*MapServiceDAO.java:generateRoute:1552*)
Exception *aala.........org.postgresql.util.PSQLException*: ERROR: Error
computing path: _
Feb 22, 2012 11:46:48 AM org.apache.catalina.core.StandardWrapperValve
invoke
SEVERE: Servlet.service() for servlet GenerateRoute threw exception
*org.hibernate.SessionException*: Session was already closed
at org.hibernate.impl.SessionImpl.close(*SessionImpl.java:303*)
at com.tis.hib.util.HibernateSessionFactory.closeSession(*
HibernateSessionFactory.java:86*)
at com.tis.dao.impl.MapServiceDAO.generateRoute(*
MapServiceDAO.java:1572*)
at com.tis.servlet.GenerateRoute.doGet(*GenerateRoute.java:125*)
at javax.servlet.http.HttpServlet.service(*HttpServlet.java:690*)
at javax.servlet.http.HttpServlet.service(*HttpServlet.java:803*)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(*
ApplicationFilterChain.java:290*)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(*
ApplicationFilterChain.java:206*)
at org.apache.catalina.core.StandardWrapperValve.invoke(*
StandardWrapperValve.java:230*)
at org.apache.catalina.core.StandardContextValve.invoke(*
StandardContextValve.java:175*)
at org.apache.catalina.core.StandardHostValve.invoke(*
StandardHostValve.java:128*)
at org.apache.catalina.valves.ErrorReportValve.invoke(*
ErrorReportValve.java:104*)
at org.apache.catalina.core.StandardEngineValve.invoke(*
StandardEngineValve.java:109*)
at org.apache.catalina.connector.CoyoteAdapter.service(*
CoyoteAdapter.java:261*)
at org.apache.coyote.http11.Http11Processor.process(*
Http11Processor.java:844*)
at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(*
Http11Protocol.java:581*)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(*
JIoEndpoint.java:447*)
at java.lang.Thread.run(*Thread.java:619*)
*Regards,*
*Palatla Srikanth*
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120222/a75a94b4/attachment-0001.html
More information about the Pgrouting-users
