[pgrouting-users] pgRouting in the cloud?
Steve Horn steve at stevehorn.cc
Fri Feb 24 08:35:07 EST 2012
AWS allows you to setup and configure several different distributions of
Linux that will support Postgres9.x/PostGIS and pgRouting.
When you create a new Linux instance you get access via SSH, but there are
articles on the internet describing how to install GUI tools so you can log
in via remote desktop/etc.
On Thu, Feb 23, 2012 at 11:05 PM, Daniel Kastl <daniel at georepublic.de>wrote:
> pgRouting works with PostgreSQL 9.x
> I compiled it on Open Suse. And I built packages for Ubuntu 11.10 64bit
> because I needed them.
> I didn't upload to Launchpad repository yet, because I wanted to test more
> first and then had no time.
> Packages are here for now:
> http://build.eq8.georepublic.net/build/oneiric-amd64_result/
> Usually issues are with boost paths, CGAL and libgmp ... not with
> PostgreSQL.
> Some compile issues and how to solve them are already mentioned in tickets.
> If packages work on AWS or not I don't know though.
> Reports about success and failure are welcome.
> Daniel
> On Fri, Feb 24, 2012 at 11:07 AM, Stephen Woodbridge <
> woodbri at swoodbridge.com> wrote:
>> Hi All,
>> Yes, I think pgRouting running on Postgres 9 is a requirement. Well I
>> don't have Postgres 9 installed here, and have not tried it, I am also not
>> away of any issues in this regard.
>> If you are trying to install from binary packages, there may be an issue
>> that the package builders have not build packages for it. If I can find
>> some time to create a Virtual Machine I'll try to install postgres 9 and
>> pgrouting and report back, but don't hold your breath, as I have been crazy
>> busy lately.
>> Regarding the next release, we know we need one, but having lost our
>> developer and release manager, we are in the process of trying to get some
>> other people involved and this takes time. If you have time and want to
>> volunteer I'm sure we can come up with taks suited to your skills.
>> Thanks,
>>  -Steve
>> On 2/23/2012 6:33 PM, Max Weninger wrote:
>>> Hi
>>> Sorry - didnt noticed that this is postgres 9
>>> I think "official" support for postgres 9 is coming in
>>> the next pgrouting release but the "experts" here should give
>>> an answer to that.
>>> Regards
>>> max
>>> On Thu, 23 Feb 2012 23:14:13 +0000
>>> James David Smith<james.david.smith at gmail.**com<james.david.smith at gmail.com>>
>>>  wrote:
>>>  Hi all,
>>>> Thanks for the replies, and especially to Max for the link to the
>>>> installation guide. Unfortunately that's beyond me, I work in Windows
>>>> at the moment and have only limited experience of using linux.
>>>> 'Opening a terminal window' was about as far as I got before not
>>>> really knowing what to do! I guess that the terminal window would need
>>>> running from within the AWS service too, so even if I knew how to open
>>>> a terminal window and start entering those commands I'd first need to
>>>> somehow be able to do that from within AWS - which I don't. Also I
>>>> note that the AWS PostgreSQL cloud service is for PostgreSQL 9.0 and
>>>> 9.1, whereas the instructions you gave Max seem to relate to
>>>> PostgreSQL 8.4 - and hence wouldn't be compatible...?
>>>> Sorry for being a bit of a newbie - still learning! This would all be
>>>> pretty cool if I only had the know-how.....!
>>>> James
>>>> On 23 February 2012 22:59, Max Weninger<max.weninger at gmail.**com<max.weninger at gmail.com>
>>>> wrote:
>>>>> Hi
>>>>> On Thu, 23 Feb 2012 22:45:07 +0000
>>>>>  wrote:
>>>>>  But I am less sure about pgRouting. There aren't any guides that I
>>>>>> can find.
>>>>> Try this one
>>>>> http://workshop.pgrouting.org/**chapters/installation.html<http://workshop.pgrouting.org/chapters/installation.html>
>>>>> Regards
>>>>> max
>>>>> ______________________________**_________________
>>>>> Pgrouting-users mailing list
>>>>> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
>>>>> http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
Steve Horn
http://www.stevehorn.cc
http://twitter.com/stevehorn
740-503-2300
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120224/ea5b3af3/attachment.html
More information about the Pgrouting-users mailing list
