[pgrouting-users] pgRouting in the cloud?
Daniel Kastl daniel at georepublic.de
Fri Feb 24 08:43:29 EST 2012
On Fri, Feb 24, 2012 at 10:35 PM, Steve Horn <steve at stevehorn.cc> wrote:
> AWS allows you to setup and configure several different distributions of
> Linux that will support Postgres9.x/PostGIS and pgRouting.
> When you create a new Linux instance you get access via SSH, but there are
> articles on the internet describing how to install GUI tools so you can log
> in via remote desktop/etc.
Ah, what was written before is all about the regular AWS?
I thought there is something new when I read ...
> I have noticed that recently Amazon Web Services offer PostgreSQL as a
> cloud database solution.
If you can setup any Linux OS you like there is no reason why pgRouting
shouldn't be installable, right?
Daniel
> On Thu, Feb 23, 2012 at 11:05 PM, Daniel Kastl <daniel at georepublic.de>wrote:
>> pgRouting works with PostgreSQL 9.x
>> I compiled it on Open Suse. And I built packages for Ubuntu 11.10 64bit
>> because I needed them.
>> I didn't upload to Launchpad repository yet, because I wanted to test
>> more first and then had no time.
>> Packages are here for now:
>> http://build.eq8.georepublic.net/build/oneiric-amd64_result/
>> Usually issues are with boost paths, CGAL and libgmp ... not with
>> PostgreSQL.
>> Some compile issues and how to solve them are already mentioned in
>> tickets.
>> If packages work on AWS or not I don't know though.
>> Reports about success and failure are welcome.
>> Daniel
>> On Fri, Feb 24, 2012 at 11:07 AM, Stephen Woodbridge <
>> woodbri at swoodbridge.com> wrote:
>>> Hi All,
>>> Yes, I think pgRouting running on Postgres 9 is a requirement. Well I
>>> don't have Postgres 9 installed here, and have not tried it, I am also not
>>> away of any issues in this regard.
>>> If you are trying to install from binary packages, there may be an issue
>>> that the package builders have not build packages for it. If I can find
>>> some time to create a Virtual Machine I'll try to install postgres 9 and
>>> pgrouting and report back, but don't hold your breath, as I have been crazy
>>> busy lately.
>>> Regarding the next release, we know we need one, but having lost our
>>> developer and release manager, we are in the process of trying to get some
>>> other people involved and this takes time. If you have time and want to
>>> volunteer I'm sure we can come up with taks suited to your skills.
>>> Thanks,
>>>  -Steve
>>> On 2/23/2012 6:33 PM, Max Weninger wrote:
>>>> Hi
>>>> Sorry - didnt noticed that this is postgres 9
>>>> I think "official" support for postgres 9 is coming in
>>>> the next pgrouting release but the "experts" here should give
>>>> an answer to that.
>>>> Regards
>>>> max
>>>> On Thu, 23 Feb 2012 23:14:13 +0000
>>>> James David Smith<james.david.smith at gmail.**com<james.david.smith at gmail.com>>
>>>>  wrote:
>>>>  Hi all,
>>>>> Thanks for the replies, and especially to Max for the link to the
>>>>> installation guide. Unfortunately that's beyond me, I work in Windows
>>>>> at the moment and have only limited experience of using linux.
>>>>> 'Opening a terminal window' was about as far as I got before not
>>>>> really knowing what to do! I guess that the terminal window would need
>>>>> running from within the AWS service too, so even if I knew how to open
>>>>> a terminal window and start entering those commands I'd first need to
>>>>> somehow be able to do that from within AWS - which I don't. Also I
>>>>> note that the AWS PostgreSQL cloud service is for PostgreSQL 9.0 and
>>>>> 9.1, whereas the instructions you gave Max seem to relate to
>>>>> PostgreSQL 8.4 - and hence wouldn't be compatible...?
>>>>> Sorry for being a bit of a newbie - still learning! This would all be
>>>>> pretty cool if I only had the know-how.....!
>>>>> James
>>>>> On 23 February 2012 22:59, Max Weninger<max.weninger at gmail.**com<max.weninger at gmail.com>
>>>>> wrote:
>>>>>> Hi
>>>>>> On Thu, 23 Feb 2012 22:45:07 +0000
>>>>>>  wrote:
>>>>>>  But I am less sure about pgRouting. There aren't any guides that I
>>>>>>> can find.
>>>>>> Try this one
>>>>>> http://workshop.pgrouting.org/**chapters/installation.html<http://workshop.pgrouting.org/chapters/installation.html>
>>>>>> Regards
>>>>>> max
>>>>>> ______________________________**_________________
>>>>>> Pgrouting-users mailing list
>>>>>> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
>>>>>> http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de
>> Web: http://georepublic.de
> Steve Horn
> http://www.stevehorn.cc
> http://twitter.com/stevehorn
> 740-503-2300
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120224/e3490230/attachment-0001.html
More information about the Pgrouting-users mailing list
