[pgrouting-users] pgRouting in the cloud?
George Silva
georger.silva at gmail.com
Fri Feb 24 08:47:38 EST 2012
Correct, there is no technical impossibilities.
On Fri, Feb 24, 2012 at 10:43 AM, Daniel Kastl <daniel at georepublic.de>wrote:
> On Fri, Feb 24, 2012 at 10:35 PM, Steve Horn <steve at stevehorn.cc> wrote:
>> AWS allows you to setup and configure several different distributions of
>> Linux that will support Postgres9.x/PostGIS and pgRouting.
>> When you create a new Linux instance you get access via SSH, but there
>> are articles on the internet describing how to install GUI tools so you can
>> log in via remote desktop/etc.
> Ah, what was written before is all about the regular AWS?
> I thought there is something new when I read ...
> > I have noticed that recently Amazon Web Services offer PostgreSQL as a
> > cloud database solution.
> If you can setup any Linux OS you like there is no reason why pgRouting
> shouldn't be installable, right?
> Daniel
>> On Thu, Feb 23, 2012 at 11:05 PM, Daniel Kastl <daniel at georepublic.de>wrote:
>>> pgRouting works with PostgreSQL 9.x
>>> I compiled it on Open Suse. And I built packages for Ubuntu 11.10 64bit
>>> because I needed them.
>>> I didn't upload to Launchpad repository yet, because I wanted to test
>>> more first and then had no time.
>>> Packages are here for now:
>>> http://build.eq8.georepublic.net/build/oneiric-amd64_result/
>>> Usually issues are with boost paths, CGAL and libgmp ... not with
>>> PostgreSQL.
>>> Some compile issues and how to solve them are already mentioned in
>>> tickets.
>>> If packages work on AWS or not I don't know though.
>>> Reports about success and failure are welcome.
>>> Daniel
>>> On Fri, Feb 24, 2012 at 11:07 AM, Stephen Woodbridge <
>>> woodbri at swoodbridge.com> wrote:
>>>> Hi All,
>>>> Yes, I think pgRouting running on Postgres 9 is a requirement. Well I
>>>> don't have Postgres 9 installed here, and have not tried it, I am also not
>>>> away of any issues in this regard.
>>>> If you are trying to install from binary packages, there may be an
>>>> issue that the package builders have not build packages for it. If I can
>>>> find some time to create a Virtual Machine I'll try to install postgres 9
>>>> and pgrouting and report back, but don't hold your breath, as I have been
>>>> crazy busy lately.
>>>> Regarding the next release, we know we need one, but having lost our
>>>> developer and release manager, we are in the process of trying to get some
>>>> other people involved and this takes time. If you have time and want to
>>>> volunteer I'm sure we can come up with taks suited to your skills.
>>>> Thanks,
>>>> -Steve
>>>> On 2/23/2012 6:33 PM, Max Weninger wrote:
>>>>> Hi
>>>>> Sorry - didnt noticed that this is postgres 9
>>>>> I think "official" support for postgres 9 is coming in
>>>>> the next pgrouting release but the "experts" here should give
>>>>> an answer to that.
>>>>> Regards
>>>>> max
>>>>> On Thu, 23 Feb 2012 23:14:13 +0000
>>>>> James David Smith<james.david.smith at gmail.**com<james.david.smith at gmail.com>>
>>>>> wrote:
>>>>> Hi all,
>>>>>> Thanks for the replies, and especially to Max for the link to the
>>>>>> installation guide. Unfortunately that's beyond me, I work in Windows
>>>>>> at the moment and have only limited experience of using linux.
>>>>>> 'Opening a terminal window' was about as far as I got before not
>>>>>> really knowing what to do! I guess that the terminal window would need
>>>>>> running from within the AWS service too, so even if I knew how to open
>>>>>> a terminal window and start entering those commands I'd first need to
>>>>>> somehow be able to do that from within AWS - which I don't. Also I
>>>>>> note that the AWS PostgreSQL cloud service is for PostgreSQL 9.0 and
>>>>>> 9.1, whereas the instructions you gave Max seem to relate to
>>>>>> PostgreSQL 8.4 - and hence wouldn't be compatible...?
>>>>>> Sorry for being a bit of a newbie - still learning! This would all be
>>>>>> pretty cool if I only had the know-how.....!
>>>>>> James
>>>>>> On 23 February 2012 22:59, Max Weninger<max.weninger at gmail.**com<max.weninger at gmail.com>
>>>>>> wrote:
>>>>>>> Hi
>>>>>>> On Thu, 23 Feb 2012 22:45:07 +0000
>>>>>>> wrote:
>>>>>>> But I am less sure about pgRouting. There aren't any guides that I
>>>>>>>> can find.
>>>>>>> Try this one
>>>>>>> http://workshop.pgrouting.org/**chapters/installation.html<http://workshop.pgrouting.org/chapters/installation.html>
>>>>>>> Regards
>>>>>>> max
>>>>>>> ______________________________**_________________
>>>>>>> Pgrouting-users mailing list
>>>>>>> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
>>>>>>> http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
>>> Georepublic UG & Georepublic Japan
>>> eMail: daniel.kastl at georepublic.de
>>> Web: http://georepublic.de
>> Steve Horn
>> http://www.stevehorn.cc
>> http://twitter.com/stevehorn
>> 740-503-2300
George R. C. Silva
Desenvolvimento em GIS
http://geoprocessamento.net
http://blog.geoprocessamento.net
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120224/90b6606b/attachment.html
More information about the Pgrouting-users
