[pgrouting-users] pgRouting in the cloud?
Steve Horn steve at stevehorn.cc
Fri Feb 24 09:23:42 EST 2012
I should have mentioned I was specifically speaking of the Elastic Cloud
Compute service (EC2).
It is relatively easy to get an idea for what is possible by tinkering
around for a couple hours on their site:  http://aws.amazon.com/ec2/
Within 45 minutes to an hour with no existing knowledge of the product you
should be able to have an instance up and running.
On Fri, Feb 24, 2012 at 8:47 AM, George Silva <georger.silva at gmail.com>wrote:
> Correct, there is no technical impossibilities.
> On Fri, Feb 24, 2012 at 10:43 AM, Daniel Kastl <daniel at georepublic.de>wrote:
>> On Fri, Feb 24, 2012 at 10:35 PM, Steve Horn <steve at stevehorn.cc> wrote:
>>> AWS allows you to setup and configure several different distributions of
>>> Linux that will support Postgres9.x/PostGIS and pgRouting.
>>> When you create a new Linux instance you get access via SSH, but there
>>> are articles on the internet describing how to install GUI tools so you can
>>> log in via remote desktop/etc.
>> Ah, what was written before is all about the regular AWS?
>> I thought there is something new when I read ...
>> > I have noticed that recently Amazon Web Services offer PostgreSQL as a
>> > cloud database solution.
>> If you can setup any Linux OS you like there is no reason why pgRouting
>> shouldn't be installable, right?
>> Daniel
>>> On Thu, Feb 23, 2012 at 11:05 PM, Daniel Kastl <daniel at georepublic.de>wrote:
>>>> pgRouting works with PostgreSQL 9.x
>>>> I compiled it on Open Suse. And I built packages for Ubuntu 11.10 64bit
>>>> because I needed them.
>>>> I didn't upload to Launchpad repository yet, because I wanted to test
>>>> more first and then had no time.
>>>> Packages are here for now:
>>>> http://build.eq8.georepublic.net/build/oneiric-amd64_result/
>>>> Usually issues are with boost paths, CGAL and libgmp ... not with
>>>> PostgreSQL.
>>>> Some compile issues and how to solve them are already mentioned in
>>>> tickets.
>>>> If packages work on AWS or not I don't know though.
>>>> Reports about success and failure are welcome.
>>>> Daniel
>>>> On Fri, Feb 24, 2012 at 11:07 AM, Stephen Woodbridge <
>>>> woodbri at swoodbridge.com> wrote:
>>>>> Hi All,
>>>>> Yes, I think pgRouting running on Postgres 9 is a requirement. Well I
>>>>> don't have Postgres 9 installed here, and have not tried it, I am also not
>>>>> away of any issues in this regard.
>>>>> If you are trying to install from binary packages, there may be an
>>>>> issue that the package builders have not build packages for it. If I can
>>>>> find some time to create a Virtual Machine I'll try to install postgres 9
>>>>> and pgrouting and report back, but don't hold your breath, as I have been
>>>>> crazy busy lately.
>>>>> Regarding the next release, we know we need one, but having lost our
>>>>> developer and release manager, we are in the process of trying to get some
>>>>> other people involved and this takes time. If you have time and want to
>>>>> volunteer I'm sure we can come up with taks suited to your skills.
>>>>> Thanks,
>>>>>  -Steve
>>>>> On 2/23/2012 6:33 PM, Max Weninger wrote:
>>>>>> Hi
>>>>>> Sorry - didnt noticed that this is postgres 9
>>>>>> I think "official" support for postgres 9 is coming in
>>>>>> the next pgrouting release but the "experts" here should give
>>>>>> an answer to that.
>>>>>> Regards
>>>>>> max
>>>>>> On Thu, 23 Feb 2012 23:14:13 +0000
>>>>>> James David Smith<james.david.smith at gmail.**com<james.david.smith at gmail.com>>
>>>>>>  wrote:
>>>>>>  Hi all,
>>>>>>> Thanks for the replies, and especially to Max for the link to the
>>>>>>> installation guide. Unfortunately that's beyond me, I work in Windows
>>>>>>> at the moment and have only limited experience of using linux.
>>>>>>> 'Opening a terminal window' was about as far as I got before not
>>>>>>> really knowing what to do! I guess that the terminal window would
>>>>>>> need
>>>>>>> running from within the AWS service too, so even if I knew how to
>>>>>>> open
>>>>>>> a terminal window and start entering those commands I'd first need to
>>>>>>> somehow be able to do that from within AWS - which I don't. Also I
>>>>>>> note that the AWS PostgreSQL cloud service is for PostgreSQL 9.0 and
>>>>>>> 9.1, whereas the instructions you gave Max seem to relate to
>>>>>>> PostgreSQL 8.4 - and hence wouldn't be compatible...?
>>>>>>> Sorry for being a bit of a newbie - still learning! This would all be
>>>>>>> pretty cool if I only had the know-how.....!
>>>>>>> James
>>>>>>> On 23 February 2012 22:59, Max Weninger<max.weninger at gmail.**com<max.weninger at gmail.com>
>>>>>>> wrote:
>>>>>>>> Hi
>>>>>>>> On Thu, 23 Feb 2012 22:45:07 +0000
>>>>>>>>  wrote:
>>>>>>>>  But I am less sure about pgRouting. There aren't any guides that I
>>>>>>>>> can find.
>>>>>>>> Try this one
>>>>>>>> http://workshop.pgrouting.org/**chapters/installation.html<http://workshop.pgrouting.org/chapters/installation.html>
>>>>>>>> Regards
>>>>>>>> max
>>>>>>>> ______________________________**_________________
>>>>>>>> Pgrouting-users mailing list
>>>>>>>> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
>>>>>>>> http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
>>>> Georepublic UG & Georepublic Japan
>>>> eMail: daniel.kastl at georepublic.de
>>>> Web: http://georepublic.de
>>>> _______________________________________________
>>> Steve Horn
>>> http://www.stevehorn.cc
>>> http://twitter.com/stevehorn
>>> 740-503-2300
> George R. C. Silva
> Desenvolvimento em GIS
> http://geoprocessamento.net
> http://blog.geoprocessamento.net
Steve Horn
740-503-2300
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120224/4d7a94eb/attachment-0001.html
More information about the Pgrouting-users mailing list
