[pgrouting-users] pgrouting workshop
Daniel Kastl
daniel at georepublic.de
Wed Jul 11 03:14:38 PDT 2012
Hi Pedro,
When comparing your line with the workshop source on GitHub [1], I see that
you added "password" to the connection string.
I think you're missing a "." before "Password" and are you sure the syntax
is correct and it needs to be a capital "P"?
Daniel
[1] https://github.com/pgRouting/workshop/blob/master/web/php/pgrouting.php
On Wed, Jul 11, 2012 at 10:47 AM, Pedro Costa <pedrocostaarma at sapo.pt>wrote:
> Hi Daniel
> In apache log i found this error:
> [error] an unknown filter was not added: PHP
> [error] [client my client] PHP Parse error: syntax error, unexpected
> T_CONSTANT_ENCAPSED_STRING in 'my domain'/routing/php/pgrouting.php on line
> 42, referer:
> Line 42 is my db data:
> // Connect to database
> $con = pg_connect("dbname=".PG_DB." host=".PG_HOST." user=".PG_USER
> "Password=".PG_PASS);
> do you know what is the problem?
> Thanks
> Em 10-07-2012 17:12, Daniel Kastl escreveu:
>> server: http://pastebin.com/tdWDgj54
> You're missing quotation in line 11 ... that's when the code
> highlighting becomes weird.
> Otherwise, try to output the SQL queries to the server log and then run
> the query in the terminal.
> Like this you can see if your query is OK or not.
> Daniel
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
> Pgrouting-users mailing listPgrouting-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120711/c2b1964e/attachment.html>
More information about the Pgrouting-users
