[pgrouting-users] pgrouting workshop
Daniel Kastl
daniel at georepublic.de
Wed Jul 11 03:16:29 PDT 2012
And you're maybe missing a space as well.
$con = pg_connect("dbname=".PG_DB." host=".PG_HOST." user=".PG_USER."
password=".PG_PASS);
... might be better. Just ensure that "password" is correct.
Daniel
On Wed, Jul 11, 2012 at 12:14 PM, Daniel Kastl <daniel at georepublic.de>wrote:
> Hi Pedro,
> When comparing your line with the workshop source on GitHub [1], I see
> that you added "password" to the connection string.
> I think you're missing a "." before "Password" and are you sure the syntax
> is correct and it needs to be a capital "P"?
> Daniel
> [1]
> https://github.com/pgRouting/workshop/blob/master/web/php/pgrouting.php
> On Wed, Jul 11, 2012 at 10:47 AM, Pedro Costa <pedrocostaarma at sapo.pt>wrote:
>> Hi Daniel
>> In apache log i found this error:
>> [error] an unknown filter was not added: PHP
>> [error] [client my client] PHP Parse error: syntax error, unexpected
>> T_CONSTANT_ENCAPSED_STRING in 'my domain'/routing/php/pgrouting.php on line
>> 42, referer:
>> Line 42 is my db data:
>> // Connect to database
>> "Password=".PG_PASS);
>> do you know what is the problem?
>> Thanks
>> Em 10-07-2012 17:12, Daniel Kastl escreveu:
>>> server: http://pastebin.com/tdWDgj54
>> You're missing quotation in line 11 ... that's when the code
>> highlighting becomes weird.
>> Otherwise, try to output the SQL queries to the server log and then run
>> the query in the terminal.
>> Like this you can see if your query is OK or not.
>> Daniel
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de
>> Web: http://georepublic.de
>> Pgrouting-users mailing listPgrouting-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120711/76fed74c/attachment-0001.html>
More information about the Pgrouting-users
