[pgrouting-users] pgrouting workshop
Pedro Costa
pedrocostaarma at sapo.pt
Wed Jul 11 03:16:40 PDT 2012
Thanks Daniel...
I'm trying without defining password for now.
And now i get this error:
JSON.parse: unexpected character
Em 11-07-2012 11:14, Daniel Kastl escreveu:
> Hi Pedro,
> When comparing your line with the workshop source on GitHub [1], I see
> that you added "password" to the connection string.
> I think you're missing a "." before "Password" and are you sure the
> syntax is correct and it needs to be a capital "P"?
> Daniel
> [1]
> https://github.com/pgRouting/workshop/blob/master/web/php/pgrouting.php
> On Wed, Jul 11, 2012 at 10:47 AM, Pedro Costa <pedrocostaarma at sapo.pt
> <mailto:pedrocostaarma at sapo.pt>> wrote:
> Hi Daniel
> In apache log i found this error:
> [error] an unknown filter was not added: PHP
> [error] [client my client] PHP Parse error: syntax error,
> unexpected T_CONSTANT_ENCAPSED_STRING in 'my
> domain'/routing/php/pgrouting.php on line 42, referer:
> Line 42 is my db data:
> // Connect to database
> $con = pg_connect("dbname=".PG_DB." host=".PG_HOST."
> user=".PG_USER "Password=".PG_PASS);
> do you know what is the problem?
> Thanks
> Em 10-07-2012 17:12, Daniel Kastl escreveu:
>> server: http://pastebin.com/tdWDgj54
>> You're missing quotation in line 11 ... that's when the code
>> highlighting becomes weird.
>> Otherwise, try to output the SQL queries to the server log and
>> then run the query in the terminal.
>> Like this you can see if your query is OK or not.
>> Daniel
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de
>> <mailto:daniel.kastl at georepublic.de>
>> Web: http://georepublic.de <http://georepublic.de/>
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org <mailto:Pgrouting-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120711/8e83ffff/attachment.html>
More information about the Pgrouting-users
