[pgrouting-users] pgrouting workshop
Pedro Costa
pedrocostaarma at sapo.pt
Fri Jul 27 01:04:44 PDT 2012
Hi list,
I'm still playing with workshop. Now i am trying to add not only the
route layer but also a layer of points that interfere in the route .
For that i modified the php and html files like that:
My php:
http://pastebin.com/wLThyrg5
My html:
http://pastebin.com/q9E3BkwV
The problem is that the two layers come together in one response so the
openlayers can't draw the route and the points.
Can somebody help me or give me some clues?
Thank you
Em 11-07-2012 11:16, Daniel Kastl escreveu:
> And you're maybe missing a space as well.
> $con = pg_connect("dbname=".PG_DB." host=".PG_HOST." user=".PG_USER."
> password=".PG_PASS);
> ... might be better. Just ensure that "password" is correct.
> Daniel
> On Wed, Jul 11, 2012 at 12:14 PM, Daniel Kastl <daniel at georepublic.de
> <mailto:daniel at georepublic.de>> wrote:
> Hi Pedro,
> When comparing your line with the workshop source on GitHub [1], I
> see that you added "password" to the connection string.
> I think you're missing a "." before "Password" and are you sure
> the syntax is correct and it needs to be a capital "P"?
> Daniel
> [1]
> https://github.com/pgRouting/workshop/blob/master/web/php/pgrouting.php
> On Wed, Jul 11, 2012 at 10:47 AM, Pedro Costa
> <pedrocostaarma at sapo.pt <mailto:pedrocostaarma at sapo.pt>> wrote:
> Hi Daniel
> In apache log i found this error:
> [error] an unknown filter was not added: PHP
> [error] [client my client] PHP Parse error: syntax error,
> unexpected T_CONSTANT_ENCAPSED_STRING in 'my
> domain'/routing/php/pgrouting.php on line 42, referer:
> Line 42 is my db data:
> // Connect to database
> user=".PG_USER "Password=".PG_PASS);
> do you know what is the problem?
> Thanks
> Em 10-07-2012 17:12, Daniel Kastl escreveu:
>> server: http://pastebin.com/tdWDgj54
>> You're missing quotation in line 11 ... that's when the code
>> highlighting becomes weird.
>> Otherwise, try to output the SQL queries to the server log
>> and then run the query in the terminal.
>> Like this you can see if your query is OK or not.
>> Daniel
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de
>> <mailto:daniel.kastl at georepublic.de>
>> Web: http://georepublic.de <http://georepublic.de/>
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org <mailto:Pgrouting-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120727/98a593d4/attachment.html>
More information about the Pgrouting-users
