[pgrouting-users] assign_vertex_id error
James David Smith
james.david.smith at gmail.com
Tue Jun 12 07:01:54 PDT 2012
Hey Annu,
Something like:
UPDATE table SET the_geom=ST_SetSRID(the_geom, 4326);
Though I sometimes find this troublesome and find it easier just to
create a new column, and then populate it with the data. Something
like:
SELECT AddGeometryColumn ('table_name','new_geom', 4326,'POINT',2);
Then populate it by doing:
UPDATE table_name
SET new_geom = the_geom;
Hope this helps. I'm not an expert at all - somebody else may have a
better solution.
James
On 12 June 2012 14:55, Annu Anurag <i.skidoosh at gmail.com> wrote:
> I just checked the srid field in the geometry_columns. Its -1. I think that
> is causing the problem? I'm using the dataset of Delhi. It should run on
> srid=4326. How do I change it to EPSG: 4326 in my geometry column?
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
